383 or 396 ???
Old Jun 2, 2003 | 01:48 AM
Soulja_350's Avatar
Soulja_350
Default 383 or 396 ???
Topic (which one is better and why thanks)
Old Jun 2, 2003 | 10:18 AM
scorp508's Avatar
scorp508
A 383 will rev a little quicker.
Old Jun 2, 2003 | 11:29 AM
mn_vette's Avatar
mn_vette
Default Re: 383 or 396 ??? (Soulja_350)
I have yet to find a 396 owner that has regretted going that big......that means something to me.
Old Jun 2, 2003 | 12:06 PM
Rich B.'s Avatar
Rich B.
Assuming all other parts are equal (in price), the kicker is the crankshaft...
My "researching" has found that 383 vs 396, the 396 crank will be ~$1400 more...
But I'd rather say "396" if asked... :crazy:
Old Jun 2, 2003 | 12:52 PM
vader86's Avatar
vader86
Id rather have a 383. Pretty easy to do, cheap parts, revs a little faster.
I guess it depends on what you want out of it.
Old Jun 2, 2003 | 12:54 PM
J Z06's Avatar
J Z06
I like the 383.
I don't think you can go wrong with either.
Old Jun 2, 2003 | 12:57 PM
93Quasar's Avatar
93Quasar
I need educated a bit. I got a 383 shortblock in my deal when I bought my car. I'm debating it vs the stock 350 for now. It is my understanding that the 383 is a .030 over stroked 350. Where does the 396 come from? Just the crank, or more boring?
Old Jun 2, 2003 | 01:02 PM
grumpyvette's Avatar
grumpyvette
I vote 383 simply because if you use the correct FORGED PARTS that are cheaper and correctly matched to build the 383,match the dcr, cam timing,and both exhaust and intake tuning, the differance will be almost not measurable and if you think that that extra 13 inchs of displacement and slightly longer stroke are a big plus your kidding yourself, use the money saved on better cylinder heads, port work, and a better quality roller cam, youll never know the differance! why you see the better results with most 396 combos is because guys that go for the extra expence in the short block also tend to spend more on the other parts that really matter like machine work, cylinder head work and better matched cams. most guys building a 396 don,t just ask their buddy what cam worked in their engine, they tend to research the parts in the combo , and tend to have a good( SOMETIMES EXPENSIVE) shop do some or all the assembly work, while many guys building the more comon 383s tend to buy kits and just slap them together, with little understanding of how small changes in port work,cylinder head porting, compression and valve work can have a big effect on hp/tq
we have all seen guys put box stock heads on a 383, but most guys spending the money to build a 396 take the time to get port work, and professional advise durring the build!
[Modified by grumpyvette, 6:09 PM 6/2/2003]
Old Jun 2, 2003 | 08:35 PM
keefyboy's Avatar
keefyboy
Speed Demon motorsports sells either 383 or 396 both forged for the same price. It may only be 13CI, but for the same price would you want a Large or a Super Size coke? :D
-keith
Old Jun 2, 2003 | 09:20 PM
GlockLT4's Avatar
GlockLT4
Default Re: 383 or 396 ??? (keefyboy)
-keith
haha.. that's the only place i've heard of them being the same ... definitely 396 if they are the same.. usually the 383 is cheaper though. I am yet to find a 396 crank that isn't forged though - unlike 383 ones.
Old Jun 2, 2003 | 09:23 PM
scorp508's Avatar
scorp508
Default Re: 383 or 396 ??? (GlockLT4)
The thing is that you can get something like a Scat 9000 cast crank good to 600HP for a 383 for a measly $275 or so, but there are NO 3.875" cranks I know of that are cast for a 396.
[Modified by scorp508, 9:27 PM 6/2/2003]
Old Jun 2, 2003 | 09:25 PM
hippy's Avatar
hippy
As the old saying goes there is no replacement for displacement. If money is NO object then bigger is better. Bang for buck, 383.
Old Jun 2, 2003 | 09:39 PM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
I like the 396! :D
Old Jun 2, 2003 | 09:56 PM
Hammer's Avatar
Hammer
Default Re: 383 or 396 ??? (savewave)
I’m getting an engine built now, all forged. The cost for doing an all forged 383 and 396 are the same.
I was hell bent on getting a 396, I love the sound of saying 396, 383 has no nostalgia (to chevy :) ).
I changed my mind and did a 383 when I started thinking about how much nitrous I’m gonna spray. It will have a direct port 200 shot (and hopefully not go any bigger). The geometry of the 383 is a little more forgiving than the 396 with nitrous.
If you’re talking about no nitrous or up to a 150 shot, 396 all the way.
Old Jun 2, 2003 | 09:58 PM
scorp508's Avatar
scorp508
How many people have BROKEN a cast crank? Is it worth it for forged? :blueangel:
Old Jun 2, 2003 | 10:02 PM
Hammer's Avatar
Hammer
Default Re: (scorp508)
I don't know, but with the amount entire engine build was costing I felt more comfortable going with forged.
Jim
Old Jun 2, 2003 | 10:11 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
scorp you are right on this one you get a cigar, the cast crank is fine the pistons and rods are your weak link get forged stuf there and you will be happy the 396 is going to have more down low and up high just because its the larger of the two i would say every thing being equal it should make more torque than a equivalent 406 but the 406 will out horse it because of the cubes :cheers:
To 383 or 396 ???
Old Jun 3, 2003 | 12:11 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
More cubes = more power potential
Afterall, the engine is just a big air pump the more air you can move, the more power you can make.
Old Jun 3, 2003 | 12:52 PM
vvv90's Avatar
vvv90
Default Re: 383 or 396 ??? (Vette92)
O.k. then I'll ask......which one if you have forced induction???? I want a 383 or 396 when I break something which I'm sure I will.....what are your opinions???
I'm thinking since I should go forged everything I should just go with the 396???
One more question...what makes the 406 different...price wise, etc...?
Old Jun 3, 2003 | 12:54 PM
Soulja_350's Avatar
Soulja_350
can u Procharge D-1 a 396? or 383?
