Stock Exhaust...how restrictive???
Old Jun 2, 2003 | 12:18 PM
mn_vette's Avatar
mn_vette
Default Stock Exhaust...how restrictive???
I should be getting my stroker motor back next week and I'm wondering if I've got the exhaust to back it up. I've got a set of Hooker longtube headers to go with it, but everything else after that is stock LT1 exhaust. Would it be worth the $/hp to get some new mufflers, or would I need a whole new catback at this point? After paying for the engine I've not got much left to get exhaust a $1000+ catback would be out of the question, but <500 I might be able to swing and just stick to Romen for the next couple of weeks. Thanks for the input.
[Modified by mn_vette, 5:26 PM 6/2/2003]
Old Jun 2, 2003 | 12:44 PM
vader86's Avatar
vader86
Default Re: Stock Exhaust...how restrictive??? (mn_vette)
I would just wait and save up the money if you have an expensive one in mind, the stock catback isnt that restrictive on LT1s. The exhaust manifolds are the really restrictive part. If you like Flowmaster, you could probably swing something for ~$500-600 though.
Old Jun 2, 2003 | 02:40 PM
mn_vette's Avatar
mn_vette
Default Re: Stock Exhaust...how restrictive??? (vader86)
I've got nothing in mind......So it's not worth it to just replace the mufflers? Any suggested size(inner diameter tube) of a catback I should get?
Old Jun 4, 2003 | 06:23 PM
mn_vette's Avatar
mn_vette
TTT
Old Jun 4, 2003 | 07:07 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I would not worry about it right now if I were you. I would be more focused on getting the motor back in there and tuned prior to spending the wad on the exhaust. You never know what little things you might encounter that are more important to spend the money on trying to get the car in order.
It is not going to hurt you much, if any at all.
Old Jun 4, 2003 | 07:25 PM
65Z01's Avatar
65Z01
Before you change it over you might tap into the exhaust pipe and measure the back pressure.
If it is aroun 1-2psi at WOT, leave it alone; if around 5-6psi or more you need to upgrade.
In the latter case go with at least 2 1/2" mandrel bent pipes.
To Stock Exhaust...how restrictive???
