Fuel System Question
Old Jun 2, 2003 | 02:07 PM
RM 4 TWO's Avatar
RM 4 TWO
Default Fuel System Question
I have a 92 LT1 with a stock fuel system. I get a buzzing sound from my fuel system after I turn the vehicle off? It’s coming from the back of the vehicle, so I assume it’s the pump or the sending unit? I say it’s the fuel system because I can pull the primary fuel pump fuse and it stops. The problem is, if I don’t pull the fuse, it doesn’t stop and eventually drains my battery. The pump is about a year old. Any thoughts?
Old Jun 2, 2003 | 02:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Fuel System Question (RM 4 TWO)
It sounds like either the fuel pump relay or the oil pressure switch is maintaining +12Vdc to the fuel pump.
Try pulling the relay as it's easiest to access; the oil pressure switch is the one with two wires.
