Superram Nitrous backfire-----
Old Jun 2, 2003 | 03:30 PM
85superram's Avatar
85superram
Default Superram Nitrous backfire-----
Well I ran through about 10 bottles successfully without a nitrous backfire. Then my knock sensor wire burnt on my headers which grounded it and took out a lot of timing. I sprayed it not knowing and it backfired through the intake.
Now the car backfires through the intake whenever its cold. If I let it warm up it wont pop but whenever its cold it will. It does it with or without the MAF sensor hooked up.
I replaced the MAF sensor thinking that was it but it still does it....What could I have done to cause it to backfire all the time now when cold??? Hurt a valve maybe???
[Modified by 85superram, 2:31 PM 6/2/2003]
Old Jun 2, 2003 | 03:56 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Superram Nitrous backfire----- (85superram)
possibly, run a compression check, that will tell you real quick.
Old Jun 2, 2003 | 04:31 PM
85superram's Avatar
85superram
Default Re: Superram Nitrous backfire----- (bill mcdonald)
what throws me off is that it runs perfectly fine when warm.......
Old Jun 2, 2003 | 04:52 PM
TIMSPEED's Avatar
TIMSPEED
That's a damn good question...Maybe you have a fuel leak somewhere?
Old Jun 2, 2003 | 04:59 PM
85superram's Avatar
85superram
Default Re: Superram Nitrous backfire----- (TIMSPEED)
Maybe a bad injector?
Old Jun 2, 2003 | 05:55 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
burnt intake valve :cheers:
To Superram Nitrous backfire-----
