Do I need a new transmission?
Old Jun 2, 2003 | 08:14 PM
vincestephens's Avatar
vincestephens
1st Gear
Default Do I need a new transmission?
When driving normal, everything shifts normally....but.....anytime I punch it, the car revs to 6-7K RPM's and never shifts. I can recreate this but putting the car in 2nd, try accelerating quickly and try to shift to 3rd, at that time, the tranny slips and I must decelerate in order for it to shift. Is it time to rebuild? Any recommnedations if I have to rebuild?
Old Jun 2, 2003 | 08:23 PM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: Do I need a new transmission? (vincestephens)
I had a question on whether I needed a new tranny once and a transmission specialist told me that if there were pieces of tranny in the pan when I removed it, it definitely needed a new one. If there were no pieces, the prob was either just needing a new filter and fluid change or was external like a modulator, wiring, etc.
You'll have to pull the trans pan but this will tell you for sure. Or have a mechanic do a trans service and report what he finds. If there are parts in the pan when he removes it, tell him to just button it back up, charge you for the fluid and his time. Save the filter charge.
BIG JIM
Old Jun 2, 2003 | 09:10 PM
scorp508's Avatar
scorp508
Default Re: Do I need a new transmission? (BIG JIM 54)
How are you getting a car with something like a 5850 rev limiter to shift to 7k?
To Do I need a new transmission?
