SAFELY CLEANING THE ENGINE
Old Jun 2, 2003 | 11:39 PM
Southern Comfort's Avatar
Southern Comfort
Default SAFELY CLEANING THE ENGINE
Whats the best way to safely clean the engine...so much electronics. in the old days you put a plastic bag on the distributor....lol am I dating myself? :banghead:
Old Jun 3, 2003 | 12:00 AM
vader86's Avatar
vader86
Default Re: SAFELY CLEANING THE ENGINE (Southern Comfort)
Dont douse the distributor, and youll be ok.
I wouldnt spray any cleaner or anything on the MAF connections though.
Old Jun 3, 2003 | 12:02 AM
jimswhite92's Avatar
jimswhite92
Simple Green , Rags , a toothbrush and a lot of time.
Old Jun 3, 2003 | 12:06 AM
vader86's Avatar
vader86
Default Re: SAFELY CLEANING THE ENGINE (jimswhite92)
He doesnt have an Optispark :D
Old Jun 3, 2003 | 12:14 AM
TA's Avatar
TA
I do use a plastic bag to cover the dist cap, just to be on the safe side, but you shouldn't have too many problems cleaning an L98
Old Jun 3, 2003 | 12:30 AM
jimswhite92
Default Re: SAFELY CLEANING THE ENGINE (vader86)
My bad ... failed to check the model
Old Jun 3, 2003 | 12:51 AM
Southern Comfort
Thanks....pressure washer ok I guess. kind of a dull engine. I need to jazz it up on my overhaul
Old Jun 3, 2003 | 09:48 AM
TA's Avatar
TA
:thumbs:
Old Jun 3, 2003 | 10:22 AM
TALMADGE's Avatar
TALMADGE
Default Re: SAFELY CLEANING THE ENGINE (TA)
Cleaned mine 2 weeks ago. I used simple green, worked great, the only problem is that I must have dowsed the TPS. After driving it later that day the RPM's started acting crazy. Finally gave that code 21. Be careful of the TPS also. I had to replace mine.
Old Jun 3, 2003 | 11:55 AM
Vic'89's Avatar
Vic'89
Default Re: SAFELY CLEANING THE ENGINE (TALMADGE)
I pulled all the accessories from the front of the motor and fully degreased it last year. I used my power washer and it did a great job.
Vic
To SAFELY CLEANING THE ENGINE
