Questions on the Mez pump
Thanks guys :cheers:
http://www.hashmarks.com/techtips/hot_cam.htm
about my HOT Cam install and page down. Btw...I did place a rubber pad between the bottom of the MAF sensor electronics and the pump since the MAF sensor rests on top of it.
[Modified by 96GS#007, 7:48 AM 6/3/2003]
You can remove just the pump, in fact the HD (those prices are about average) has to be installed after the pump housing is inplace. It clears the A/C accumulator by only about 3/8".
I used a Barry Grant fuel pump relay (pic #66 in the HOT Cam write-up :D) It's rated at 30A. The Mez heavy duty pump pulls 9A, so there's plenty of margin.
Everything else came with the pump. However....
I did three other things...
- The in-line 20A fuse holder that comes with the MEZ is a cheap POS. Replace it with a quality 30A fuse holder, but be sure to install a 20A fuse. $5 is cheap insurance.
- There's a cheap interference style electrical connector between the pump wiring and the wire leads that run to ground and relay power. I cut that connector off and replaced it with a weather-resistant, positive locking weatherpack connector (see pic 75 in the HOT Cam write-up :D)
- I replaced the o-ring seal that goes between the pump and the housing. The directions say to re-use the old one, but for a $1 or so from Jeff Kopp, why not put a new one on?!
Other than the two things I changed...I've been very pleased with the pump. Last month I did some lapping sessions at Hallett Motor Racing Circuit. Coolant temps were not an issue (I also have a 160* t-stat and I've reprogrammed my fans using LT1 Edit to come on sooner). I did see my oil temp hit 304*...
:flag :flag :flag
