overheating
Old Jun 3, 2003 | 01:51 PM
91VetteGirL's Avatar
91VetteGirL
Cruising
Default overheating
My 91 'vette overheats in in the hot weather, when it's idle. Sometimes the fan's don't work. Isn't there something I canput on it to make the fans kick on??
Please help me.Thanks :blueangel:
Old Jun 3, 2003 | 02:03 PM
ELEVENS's Avatar
ELEVENS
Default Re: overheating (91VetteGirL)
Well, you are definitely going to need your fan or fans to turn on when the coolant temp gets up there. I think MidAmerica and/or Echlers have a manual fan switch you can install.
But another very common problem is the radiator getting full of junk. The C4 Corvette is a very efficient vacuum cleaner, traveling down the public roads sucking up all the light stuff - leaves, cottonwood fluff, dog hair, etc. and depositing the dirt onto your radiator. Everyone that I have heard of who removed their radiator (including me) was shocked at how clogged up it was.
:cheers: -Bill
[Modified by ELEVENS, 2:04 PM 6/3/2003]
Old Jun 3, 2003 | 02:15 PM
Steel Blue 91's Avatar
Steel Blue 91
What temps are you seeing? An estimate is fine since you have the same analogs I do. A stock C4 will run ~238* in traffic before the main fan comes on. The general did this for a number of reasons, ie. emissions. If your radiator is clean, the coolant is good and green and your thermostat is not stuck there are a few ways to bring the temps down. Manual fan switch, programed chip, etc. If you are not seeing temps up around 250* or so it would be considered "normal".
Old Jun 3, 2003 | 03:06 PM
vader86's Avatar
vader86
The main fan should come on at 228F, is it not coming on at all? I would check the connections and especially the fan relay.
Overheating is a common problem for C4s, GM designed them to run hot to pass emissions, so temps in the 200-230 range are not abnormal.
The stock thermostat is 195, in TX i would definitely change it to a 160. Its about to get really hot down there, if its not terrible already.
Then, you MUST remove the radiator shroud and clean the space between the radiator and condensor, its blocking airflow and cleaning it tends to drop temps by 10-20F.
Only real permanent fix though is to buy a fan switch, from Ecklers or MidAmerica, wire it to the main fan so it will come on sooner. That will keep it from overheating.
Old Jun 3, 2003 | 06:02 PM
91VetteGirL
Cruising
Default Re: overheating (vader86)
it comes on sometimes. I will try that. Thank you
Old Jun 3, 2003 | 06:04 PM
91VetteGirL
Cruising
Default Re: overheating (Steel Blue 91)
260+. I will try to clean my radiator and see how that works. Thank you
Old Jun 3, 2003 | 07:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Cleaning the debris will help for sure.
In hot climates the automatic fan switch from MAD or Eckler's would be nice. They have one that works around your stock 195 deg stat or you can put in a lower temp stat and fan switch for even lower temps.
Old Jun 4, 2003 | 12:46 AM
CarAteMyMoney's Avatar
CarAteMyMoney
Regardless of how much crap is blocking your radiator, the fans are set to go on at a given temperature. The crap in the radiator will just help the car get there faster
If the fans aren't going on when they're supposed to, you have a different issue like a relay or maybe a temp sender
If you want to make them come on sooner, I believe either Summit or Jegs sells different senders that make them come on at different times. Also i'd do the thermostat
[Modified by CarAteMyMoney, 1:49 AM 6/4/2003]
Old Jun 4, 2003 | 01:36 AM
hngacurv's Avatar
hngacurv
Default Re: overheating (CarAteMyMoney)
260* :eek: I would check everything involved with the fan. Relays, fan switch, and wiring.
Old Jun 11, 2003 | 12:54 PM
91VetteGirL
Cruising
Default Re: overheating (ELEVENS)
Can you please tell me how to get to MidAmercia. I have looked and would like to find that switch. thanks
Old Jun 11, 2003 | 01:05 PM
neverendingproject's Avatar
neverendingproject
www.madirect.com
Old Jun 11, 2003 | 01:16 PM
Red Tornado's Avatar
Red Tornado
....The stock thermostat is 195, in TX i would definitely change it to a 160. Its about to get really hot down there, if its not terrible already.
This is exactly what I just did yesterday - on both counts. The difference will blow you away, a HUGE improvment! The temps are WAY down now, after driving hard and for over an hour. I strongly recommend doing both the 160 t-stat as well as the fan switch + the harness (splices into the 2 relays for the dual fans). Say hello to the end of engine cookery :eek:
Old Jun 12, 2003 | 12:05 AM
R23HTC's Avatar
R23HTC
Default Re: overheating (bradvette)
First check the radiator for obstuctions.
Stuff like that doesn't help. I also just replaced my primary fan motor as it went out and my A/C blower motor bit the dust about 2-3 weeks later. I don't know how many miles you have, but I would say it isn't out of the question that the fan may be going out.
To overheating
