LT1 intake on TPI
Old Jun 3, 2003 | 04:05 PM
Fast_vette89's Avatar
Fast_vette89
Default LT1 intake on TPI
I've been trying to upgrade the air intake system on the TPI's, b /c the air box does not flow enough CFM. Has anybody tried a LT1 air box/duct on a earlier TPI?? It's flat and wide...and that's what us TPI guys need... b/c of hood clearances over the radiator shroud.
Old Jun 3, 2003 | 04:33 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: LT1 intake on TPI (Fast_vette89)
Unsure if it would work...the later cars have a more tilted back rad and shroud setup I think.Also,why did you think the stock TPI airbox wouldnt flow enough cfm?For stock engines it flows more than enough for everyday use.
On modded engines,I guess it would depend on cube size and other mods.
:cheers:
Old Jun 3, 2003 | 04:50 PM
Fast_vette89
Default Re: LT1 intake on TPI (Bill's86Coupe)
I need it, LT1 intake manifold, headers, exhuast, custom PROM, 2,500 stall, bolts ons,etc. CFM needed, i already calculated. i'll need about 720CFM....so 750CFM is the mark. I'm probly going to make a crossover pipe out of fiberglass. about 1" tall, 10" wide and then funnel into 3" in/out . anyone have the specific CFM #'s for the TPI stock airbox.... b/c i calculated about 580CFM w/some porting done. so my guess is stock is 550CFM or around that.
Old Jun 3, 2003 | 07:17 PM
sumoboy's Avatar
sumoboy
Are you talking about the throttle body for CFM's. :confused:
To LT1 intake on TPI
