Any codes when the electronic a/c goes (intermittent) bad.
Old Jun 3, 2003 | 05:21 PM
froggy47's Avatar
froggy47
Default Any codes when the electronic a/c goes (intermittent) bad.
My electronic a/c heat is going dead on me every so often. The dealer said bring it in when it's dead. Right. Are there any codes that get set with this problem that I can educate the dealer on or do I just keep waiting til it dies for good?
Thanks.
Old Jun 3, 2003 | 07:47 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Any codes when the electronic a/c goes (intermittent) bad. (froggy47)
Go to http://www.idavette.net/techno.htm
Scroll down the left side to HVAC.............
Old Jun 3, 2003 | 08:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Yes you can pull codes right off the unit itself. The link provided is a good reference.
Old Jun 3, 2003 | 11:18 PM
froggy47's Avatar
froggy47
Default Re: Any codes when the electronic a/c goes (Vette92)
I read the article. If I do not have any blinking lights does that mean I do not have any codes????
Old Jun 4, 2003 | 02:47 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: Any codes when the electronic a/c goes (froggy47)
Try the diagnostic procedure if you have no codes you shud get a"oo" in the LED.
Old Jun 4, 2003 | 12:18 PM
froggy47's Avatar
froggy47
Default Re: Any codes when the electronic a/c goes (lou sylvestri)
will do!
Old Jun 8, 2003 | 08:44 PM
Jerry D's Avatar
Jerry D
Are these codes the same for a 86?
Old Jun 9, 2003 | 11:01 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Just because you don't see the blinking light doesn't mean there isn't an error. The light may very well blink and you miss it. Moreover error codes are not stored in the unit, you have to catch them when they occur.
So drive down the road with someone looking at the head unit. When it begins to blink, push both the upa nd down fan speed buttons for 5 seconds or until you see 00, then the auto button. Here is where you can read the codes that are occuring at that time.
More information: There are numerous codes which can be extracted from the C68 head unit that are not in the GM service manual or, Helms, Haynes or any other manual that I have run across.
Do the check and post the results.
To Any codes when the electronic a/c goes (intermittent) bad.
