4+3 Filter change
Old Jun 3, 2003 | 06:46 PM
Storz's Avatar
Storz
Default 4+3 Filter change
I just ordered the kit from MA to change the gasket and filter for the 4+3, any tips on doing this or is it pretty straight forward. I have acess to a lift so getting under the car is not a problem. Thanks
Old Jun 3, 2003 | 08:32 PM
Storz's Avatar
Storz
Default Re: 4+3 Filter change (Storz)
ttt
Old Jun 3, 2003 | 09:05 PM
LD85's Avatar
LD85
This is probably the easiest of the jobs you can do. Just dont overtighten the bolts and put a bead of gasket sealer around the lip on the gasket for extra measure.
I have done it with and without the sealer and it leaks sometimes without the sealer. :thumbs:
Old Jun 3, 2003 | 09:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 4+3 Filter change (ld85)
The best tip, is to throw the gasket away, just use rtv by itself. The gasket gives it twice as many places to leak.
Also, blow out the old fluid out of the cooling lines with compressed air.
Fill it up till it comes out the hole, drive it around a bit, then top it off. (Because cooling lines will pull a bunch of fluid in.)
Old Jun 3, 2003 | 11:56 PM
Storz's Avatar
Storz
Default Re: 4+3 Filter change (CentralCoaster)
Thanks for the tips :cool:
Old Jun 4, 2003 | 12:03 AM
scorp508's Avatar
scorp508
Throw the filter away and chemically clean the surfaces with brake cleaner. I highly recommend using RTV, letting it sit till it is "tacky" to the touch and then installing the pan and letting it sit an hour or two to let it set up some. Then fill about 3/4 quart. Jack both back wheels up and turn them with your hands. This will pump the overdrive unit and prime the lines and transmission. Crawl back under and fill it until it comes out the fill plug.
You'll probably need a small hand pump to fill it as there is no way to get a container up against hte transmission unless you flip the car over. :)
Old Jun 4, 2003 | 12:36 PM
CentralCoaster
Default Re: 4+3 Filter change (scorp508)
[Modified by CentralCoaster, 9:37 AM 6/4/2003]
Old Jun 4, 2003 | 01:54 PM
Storz's Avatar
Storz
We have a lift and a big syringe with a tube on the end to fill the OD unit back up
To 4+3 Filter change
