Cleaning the MAF sensor elements.
Old Jun 4, 2003 | 12:37 PM
BlackBeast2's Avatar
BlackBeast2
Default Cleaning the MAF sensor elements.
On a 95.
Is this even possible? Or are the tiny elements too fragile?
I was planning on buying one of the larger 'ported' MAF housings and was thinking of cleaning the sensor elements at the same time.
What do you think of just spraying them down with something like brake cleaner and alowing plenty of drying time before reassembly?
Thanks for any help guys.
Conrad.
Old Jun 4, 2003 | 12:42 PM
SeanSullivan's Avatar
SeanSullivan
Default Re: Cleaning the MAF sensor elements. (BlackBeast2)
Don't know how it'd work on the GM MAF, but on a Ford MAF it does work. Had a 93 exploder, was running rough cleaned the MAF wire smoothed right out. IF youi're going to have to replace it anyway, I would give it a try. Might've gotten some oil on it, IF you use a K&N air filter and have cleaned it recently, and reoiled it too heavily it is possible to contaminate the MAF sensor. I used brake parts cleaner, worked for me.
:chevy
Old Jun 4, 2003 | 01:16 PM
BlackBeast2
Default Re: Cleaning the MAF sensor elements. (SeanSullivan)
Thanks Sean.
I too am a recovering Ford guy with a few Mustangs in my past (still own a 5.0). I know all about the Ford meters, but the elements are a little more 'out-there' on these C4's. I was aware of the K&N oil problems and am indeed running a similar filter. I know that Pro-M often cleans MAF's that are sent to them for recalibration that have oil buit up on them. When installing my TB air-foil recently, I noticed a lot of black 'build-up' on the interior walls of my intake ducts. So I'm sure the sensors have a coat of of yuck on them as well.
Thanks for your help and input. I may try the brake cleaner. Its so fast drying and non-greasy that I think it would work.
Any body else have input?
:cheers:
Old Jun 4, 2003 | 02:01 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
That is what the burnoff relay should do, is keep it clean. It heats up at the end of each shutdown to remove any contaminants. You may want to pull the hose off and watch it to see if that is working properly. At 300+ dollars I wouldn't be spraying anything onto anything.
Just my advice :cheers:
Old Jun 4, 2003 | 02:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Cleaning the MAF sensor elements. (ski_dwn_it)
Though it may be OK to spray on a cleaner if you allow it to completely evaporate I wouldn't do it.
As mentioned the burn-off relay takes care of cleaning those wires (at least on the L98 MAF); if they are dirty service the burn-off circuit.
Old Jun 4, 2003 | 04:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Cleaning the MAF sensor elements. (65Z01)
I could be wrong, but I do not think there is a burnoff relay on the LT1 MAF's.
Old Jun 5, 2003 | 08:17 PM
1MoorTym's Avatar
1MoorTym
Default Re: Cleaning the MAF sensor elements. (Vette92)
:iagree: Only the Bosch MAFs use a burn off relay, the GM unit does not.
Old Jun 6, 2003 | 12:18 AM
konroh's Avatar
konroh
Default Re: Cleaning the MAF sensor elements. (1MoorTym)
i sprayed mine down with brake cleaner with it out of the car and upside down. No problems, although it didn't really help much of anything either...
:cheers:
Old Jun 6, 2003 | 02:29 PM
cire96's Avatar
cire96
BlackBeast:
Go ahead. Hose that baby down with brake cleaner. I've done mine and it works fine. Just don't touch it with anything - especialy your oily fingers.
Cire96
Old Jun 6, 2003 | 11:15 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Cleaning the MAF sensor elements. (cire96)
I noticed in the catalogs there were no burn off relays listed for 84-85 ?????
Old Jun 7, 2003 | 01:47 PM
The Paladin's Avatar
The Paladin
Default Re: Cleaning the MAF sensor elements. (Southern Comfort)
Rather than brake cleaner, there is an even better item - electric circuit-board cleaner. This stuff is so volatile that it evaporates like lightning, so fast that I once used it to clean some poly safety glasses and they cracked from the sudden evaporation-chilling.
The MAF wires are only 0.003" in diameter, you do NOT want to take a chance of damaging/breaking them.
[Modified by The Paladin, 1:13 PM 6/7/2003]
Old Jun 7, 2003 | 02:12 PM
Southern Comfort
I just cleaned mine this morning. Good news is it started. Hope there is no bad news.
PS it was pretty gunky in there
Old Jun 7, 2003 | 06:24 PM
Ramanstud's Avatar
Ramanstud
`84's are speed density CFI anyway (no maf) and I believe the `85's are unique enough to require their own relays. I think there might even be two relays for the `85 TPI.
:cheers:
Old Jun 8, 2003 | 06:54 AM
tommelton's Avatar
tommelton
Default Re: Cleaning the MAF sensor elements. (Ramanstud)
85's have a MAF burnoff module located near the ECM under the dash - no relays....and it is exxxxxpensive.
Tom Melton
82 CE
86 Z51 Coupe
95 M3
Old Jun 8, 2003 | 10:45 PM
lspalding's Avatar
lspalding
Default Re: Cleaning the MAF sensor elements. (The Paladin)
This sounds good. Have never cleaned my '95. Have done it a number of times on older Bosch MAFs with TB cleaner. and it works well. Notwithstanding the burn off cycle, they get crud built up on the wires.
Old Jun 8, 2003 | 11:08 PM
Lone Ranger's Avatar
Lone Ranger
Ummm... any chance that rapid action evap could cause a micro crack on one of the MAF wire's little diodes?
Myself, I used a q-tip dipped in mineral spirits to gently swab each wire and diode, then dried w/ q-tip. They're fragile, but a steady hand, light touch, and soft q-tip will not damage them.
To Cleaning the MAF sensor elements.
