distributor ?
Old Jun 4, 2003 | 06:05 PM
eddieL98's Avatar
eddieL98
Default Distributorless Ignition System
Thanks!
[Modified by eddieL98, 1:13 AM 6/6/2003]
Old Jun 4, 2003 | 06:08 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: distributor ? (eddieL98)
not sure, but what's the site that you got that picture from? the pic is pretty sweet. :thumbs:
Old Jun 4, 2003 | 06:13 PM
85z51vette's Avatar
85z51vette
Default Re: distributor ? (86_RedRider)
Looks like it may belong to this car...
http://www.turborepair.com/turbovette/87turbovette.htm
:cheers:
Old Jun 4, 2003 | 06:22 PM
scorp508's Avatar
scorp508
Default Re: distributor ? (85z51vette)
Looks like a DIS (Distributorless Ignition System) to me. If anything there "might" be a shaft where the old distributor was mearly to be used as a crank signal. Otherwise I wouldn't be surprised to see something like a magnetic crank trigger on the crankshaft pulley area somewhere.
Old Jun 4, 2003 | 06:26 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: distributor ? (scorp508)
That's an electromotive TEC ECU and ignition
http://www.electromotive-inc.com
[Modified by Twin_Turbo, 7:28 PM 6/4/2003]
Old Jun 4, 2003 | 06:27 PM
scorp508's Avatar
scorp508
Default Re: distributor ? (Twin_Turbo)
That link didn't work, any more information on it? I might be interested. :)
Old Jun 4, 2003 | 06:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Damn scorp, you're fast, I forgot the -, it's good to go now
Old Jun 4, 2003 | 06:57 PM
krivera's Avatar
krivera
they guys that owns that car..i think he is a member?
Old Jun 4, 2003 | 08:03 PM
eddieL98's Avatar
eddieL98
Default Re: distributor ? (krivera)
:thumbs: cool thanks guys. yeah i think he is a forum member. i found the link digging through the archives. the only reason i asked about the system was i was thinking of doing the LT1 intake mod but didn't want to drill the hole for the distributor. plus i thought it would look cool on one of the sides where the cover would go. just wanting to be diffrent
Old Jun 5, 2003 | 05:17 AM
Twin_Turbo's Avatar
Twin_Turbo
You thought about the oil pump right?
Old Jun 5, 2003 | 08:58 AM
Steel Blue 91's Avatar
Steel Blue 91
Talk about your smooth bore intake! Forget the traffic cones, I want one of these!
[Modified by Steel Blue 91, 9:01 AM 6/5/2003]
Old Jun 5, 2003 | 04:47 PM
eddieL98's Avatar
eddieL98
the oil pump is connected to the distro? guess i have more R&D to do.
thanks
Old Jun 5, 2003 | 05:46 PM
scorp508's Avatar
scorp508
:yesnod: The distributor shaft runs the oilpump drive shaft.
Old Jun 5, 2003 | 06:11 PM
Twin_Turbo's Avatar
Twin_Turbo
you can do it, if you use a dry sump syetem with external belt driven pump. Then you won't need the distributor at all, just a shaft in there so the oil channels are closed (otherwise you'd have a big leak where the distributor shaft would be)... still a lot of work, why not just get an LT-1 and be done with it.
Old Jun 5, 2003 | 11:56 PM
BookSmart's Avatar
BookSmart
I think if you look into the distributor problem all you have to do is find the shafts they put in the distributor hole when they crossed over to DIS and still ran the oil pump from a shaft.
Problem is you would have to drill a hole in the intake for the oil pump drive shaft so you might as well put in a distributor. Unless you just want to be diffrent. :eek:
Old Jun 6, 2003 | 02:09 AM
eddieL98's Avatar
eddieL98
Default Re: distributor ? (BookSmart)
yes i could find one of those shafts then fabricate until it fits under the intake.
no i don't want to put an LT1 in the car. just wanted to mod this one.
i guess i'll just cut the hole. thanks for all the input :cheers:
Old Jun 6, 2003 | 08:23 AM
Twin_Turbo's Avatar
Twin_Turbo
do a search on the thirdgen boards (thirdgen.org) If I'm not completely hallucinating I remember seeing a modified LT-1 there, someone modded it to accept a distributor.
To distributor ?
