Calif Smog/Headers,Lets talk about it
Old Jun 4, 2003 | 08:21 PM
james holley's Avatar
james holley
Default Calif Smog/Headers,Lets talk about it
i dont like this one bit. i have hooker long tubes on my car, and so do several other guys i know. yesterday i spoke to a guy on the phone at the california air resorces board. he said they(the smog *****) are talking about smog testing everywhere, including counties that are now exempt. Can we still make an L98 run like hell without headers turbo or NOS? :(
Old Jun 4, 2003 | 09:08 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Calif Smog/Headers,Lets talk about it (james holley)
I guess I leaned something new as I thought all of California was under the CARB umbrella and no one was exempt.
Old Jun 4, 2003 | 09:30 PM
65Z01's Avatar
65Z01
You can get your late L98 well into the 12s by doing a "cheater" front Y, cat & cat-back along with some intake mods, heads and cam.
Is there a path with the CARB for you to have a FL header setup tested and certified without mortgating the farm?
Old Jun 4, 2003 | 11:14 PM
vader86's Avatar
vader86
Well, you can put a Superram on it, its CARB legal. But then you might not call it an L98 anymore.
I dont see how you can run great times NA without headers on an L98.
Old Jun 4, 2003 | 11:59 PM
JasonL's Avatar
JasonL
There's no smog testing in the Fresno area??? Interesting, maybe the central valley Congressman who blames the bay area for the bad valley air should take some notes. That's just wonderful. :rolleyes: Sorry for ranting. :crazy:
Old Jun 5, 2003 | 12:20 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Calif Smog/Headers,Lets talk about it (JasonL)
How about gettin some heddman style (non-equal length) headers, that drop straight down, like the stock exhaust does? Then you could fabricate a little heat shield and a fake flange there.. so you could pass visual.
That sounds like the best way to go long tubes without having to swap headers twice every two years.
Old Jun 5, 2003 | 01:17 AM
TIMSPEED's Avatar
TIMSPEED
:eek: That would suck! Cuz a LOT of people here in CA get away with having non-CA smog legal cars that way. (I was going to go that route myself, but now, I guess I won't)
Old Jun 5, 2003 | 02:44 AM
CentralCoaster
Default Re: Calif Smog/Headers,Lets talk about it (TIMSPEED)
What counties are exempt? Or just exempt from visual?
I know Kern County isn't.
Old Jun 5, 2003 | 03:17 AM
pablocruise's Avatar
pablocruise
That's not so bad. What is scary(to me anyways) is them doing roadside infrared sampling. I'd be toast if I go thru one of those. My low flying aircraft would be grounded :(
Old Jun 5, 2003 | 03:43 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: Calif Smog/Headers,Lets talk about it (CentralCoaster)
Well, it's not their EXEMPT, But the only thing that you have to do in those counties, is smog your car when it's bought and sold, no biannual inspections at all.
Old Jun 5, 2003 | 03:47 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Re: Calif Smog/Headers,Lets talk about it (89 Paul in Cal)
Paul hows the custom stealth ram i was thinking of getting one when i get back from the gulf from Grumpyvette :cool: Also the hooker 2149's have the air injecter tubing rite and egr hook up?
Old Jun 5, 2003 | 01:15 PM
james holley
Paul, what is roadside infared sampling? Sounds painful
Old Jun 5, 2003 | 03:05 PM
TIMSPEED's Avatar
TIMSPEED
It's basically a machine with a big sensitive nose. If you drive by it and the alarm goes off (which I DOUBT it will), they'll follow you (or if you're in a pack, they'll follow that pack) until they can pinpoint which car it is, then when they do, they pull you over and check your stuff out. But if you have a decent running motor, even with NO CATS AT ALL, it shouldn't set off that machine.
Tip: Stay close to big rigs and diesel powered cars :D
To Calif Smog/Headers,Lets talk about it
