Help With New Clutch Selection
Old Jun 5, 2003 | 09:21 AM
LT4Thunder's Avatar
LT4Thunder
Navigator
Default Help With New Clutch Selection
I have owned my CE LT4 (first vette) about a month and the clutch has seized up. I am now in need of a new clutch kit and I'm not sure if the OEM clutch is the way to go. My car has hotcam, headers, ported heads and intake and 4:10 gears.
Can the OEM clutch handle the additional power of produced by these mods? The current clutch was stock with a McLoed pressure plate. A previous owner told me it dynoed at 365hp.
Would a trip or two a year to the drag strip and possibly a set of drag radials make difference in my clutch selection? I don't beat on the car, but power is too much of drug not to go thru the gears every now and then.:D
Any help would be appreciated.
Old Jun 5, 2003 | 12:04 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Help With New Clutch Selection (LT4Thunder)
I had great experiences with the McCleod street/strip clutch. This was with a single mass flywheel. They make the clutch disks for either single or sotck dual mass though. FWIW, all C4 ZF6 pressure plates are made by Valeo.
Old Jun 5, 2003 | 12:07 PM
FoolCrzy's Avatar
FoolCrzy
I had a centerforce in my previous car.
In my LT4, i have the stock setup. It has approx, 5,000 HARD miles, and 89 drag strip launches. seems fine so far.
Just FYI
:cheers:
Old Jun 5, 2003 | 12:12 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Help With New Clutch Selection (FoolCrzy)
FWIW,
McCleod part numbers...
For 92-96 LT1 ZF Equipped Corvettes:
Using Stock Dual Disk Flywheel
Single Disk Clutch Plate - #267871
Pressure Plate #360823
Single Mass Flywheel - #460376-1
Single Sprung Disk Clutch Plate - #261871
These were what they were two years ago when I was selling parts on the side, not sure they have changed.
LT4Thunder's Avatar
LT4Thunder
Navigator
Thanks for the responses. At $1000 for parts and install by a Chevy dealer I am hoping it lasts at least a few summers.
Old Jun 5, 2003 | 12:40 PM
bogus's Avatar
bogus
A few pointers:
1) Avoid SPEC clutches. :mad
2) you cannot resurface the dual mass flywheel. if you are drag racing, stay with the dual mass, road racing, single mass.
3) get new hydrolics. Cheap insurance.
4) Install beam plates and do ujoints, too... might as well!
5) Replace the rear main seal, too.
6) Consider an aftermarket shifter, easier to do with the tranny out!!!
Old Jun 6, 2003 | 09:37 AM
LT4POWR's Avatar
LT4POWR
Default Re: Help With New Clutch Selection (bogus)
A few pointers:
:iagree: Spend the extra money and get the McLeod.
To Help With New Clutch Selection
