Leaky injector question
Old Jun 5, 2003 | 12:19 PM
MarkHalliday's Avatar
MarkHalliday
3rd Gear
Default Leaky injector question
Hi,
What is the procedure to determine which (if any) of the injectors is leaking. Second, is there a way to repair a leaky injector or do you have to go out and buy a new one? Any help on this would be greatly appreciated.
Mark
Old Jun 5, 2003 | 12:43 PM
vader86's Avatar
vader86
Default Re: Leaky injector question (MarkHalliday)
Usually the easiest way to tell is by hooking up a pressure gauge at the rail, turning the car off, and seeing if pressure holds steady.
You can have the faulty one sent to Rich at CruizinPerformance, but you might as well send all 8. If one is leaking, another is sure to follow.
Or you can buy the Ford #24 SVO injectors.
Old Jun 5, 2003 | 12:55 PM
MrNuke's Avatar
MrNuke
Default Re: Leaky injector question (vader86)
When I had that symptom it was the fuel pump though..
When I had leaky injectors, durign a cold start the car started up right away,
but when it was warm it took a few cranks to start.. Replaced the injectors, everythign is fine since..
Old Jun 5, 2003 | 01:00 PM
scorp508's Avatar
scorp508
Default Re: Leaky injector question (MrNuke)
If I remember right....
With the fuel pump running pinch off the return fuel line and feed fuel line. Turn off the pump and monitor pressure. If it drops to 0 relatively quickly or immediatly you have an injector(s) leaky/stuck open. Pinching off both lines gives the fuel nowhere to go besides the cylinders.
Old Jun 5, 2003 | 01:54 PM
sraft's Avatar
sraft
Default Re: Leaky injector question (scorp508)
While you can determine if there is a leak, it'll be darn impossible to narrow it down to a specific injector. Send all of them to Cruzin Performance - Rich will get them working as good as new for ~$100 (includes shipping).
[Modified by sraft, 1:54 PM 6/5/2003]
Old Jun 5, 2003 | 02:05 PM
scorp508's Avatar
scorp508
Default Re: Leaky injector question (sraft)
No way its easy. Do what I did. Yank the plenum and unbolt the fuel rails from the intake manifold. Pop the injectors out of the manifold while still in the fuel rails. Place a small piece of dark colored paper under each fuel injector (hit the tips with compressed air first) and prime the fuel rails with a turn of the key. If one is leaky or stuck open you'll see it immediately.
p.s.
I would STILL get them all cleaned and/or replaced either way. At least you'll know which was the problem child.
[Modified by scorp508, 2:05 PM 6/5/2003]
Old Jun 5, 2003 | 05:09 PM
hngacurv's Avatar
hngacurv
If you had 1 leaking wouldn't that spark plug be black?
Old Jun 5, 2003 | 05:10 PM
vader86's Avatar
vader86
Also, if he's having serious startup issues, he could pull the plugs and one should look very different, probably black as coal.
Old Jun 5, 2003 | 05:43 PM
scorp508's Avatar
scorp508
When mine was hung open 100% it wasn't black, just wet. :) The spark couldn't even fire.
Old Jun 5, 2003 | 05:51 PM
sraft's Avatar
sraft
scorp,
You're so right - it's so obvious (now that you mention it), why didn't I think of that?
Cheers
To Leaky injector question
