Headlamp opening actuator fix..checkthis
Old Jun 6, 2003 | 12:26 PM
vettek50's Avatar
vettek50
Default Headlamp opening actuator fix..checkthis
this update to be applied only if your headlite motors and bushing are in good repair. Requires rewiring the motor internally. however, it is possible to do this without internal modification(according to gregg???)
What is needed is wiring a diagram to rewire the existing 3wire system to 2 wire (including the new module) conversion. 84 - 87 C4 were 3wire, 88 - 96 are 2wire systems. maybe someone could help with this?
to review"motor actuator keeps clicking after closing" refer to this thread http://forums.corvetteforum.com/zerothread?id=570000
for the fix:
http://forums.corvetteforum.com/zerothread?id=501168
for the parts:option #1
ecklers parts# 35495 head lamp opening actuator module
http://www.ecklers.com/product.asp?p...M8FVSR69KEBK49
option #2 located module at auto wreckers, firebirds use the same module 87and later
the module has two plugs 1 is 4 wire, the other is 5 wire:
1:output 4 wire, A,B, go to one lite, C,D, go to other lite
2:the other plug has five, B, E, get +12v
Old Jun 6, 2003 | 09:18 PM
vettek50's Avatar
vettek50
Default Re: Headlamp opening actuator fix..checkthis (vettek50)
please?
Old Jun 6, 2003 | 10:13 PM
vettek50's Avatar
vettek50
could someone please help us with this wiring diagram? :)
Old Jun 7, 2003 | 12:41 AM
LaVidaLoca's Avatar
LaVidaLoca
OK. Look here:
http://photos.yahoo.com/bc/black85ve...tos.yahoo.com/
In my album there are pictures of the procedure and of the wiring diagram.
I changed hosts and the links in the old post are now out of date. So I reposted them in my album on Yahoo.
Enjoy :cheers:
[Modified by LaVidaLoca, 11:43 PM 6/6/2003]
[Modified by LaVidaLoca, 11:52 PM 6/6/2003]
To Headlamp opening actuator fix..checkthis
