Performance Chips
Old Jun 7, 2003 | 01:32 AM
Black91L98's Avatar
Black91L98
Default Performance Chips
Im eventually going to buy a chip for my stock 91 L98. Hypertech and Jet Performance are the two companies Ive heard publicized the most, any suggestions, reviews?
Old Jun 7, 2003 | 01:41 AM
Dougs 90's Avatar
Dougs 90
Default Re: Performance Chips (Black91L98)
Look up ski_down_it or one of the other members here and get a custom one from them!!!
Old Jun 7, 2003 | 01:46 AM
TA's Avatar
TA
My suggestion is to use the stock chip until you have mods that require you to have a custom chip burned (heads, cam, etc.). I briefly used a Jet stage 2 chip until I did some testing at the track and realized that my car was about .15 faster in the 1/4 mile with the stock chip. :yesnod:
Old Jun 7, 2003 | 02:02 AM
vader86's Avatar
vader86
Do not buy one of these generic chips, they do nothing for you.
Get someone to burn you one to make the fans come on sooner, thats all you need until you change the cam.
Old Jun 7, 2003 | 02:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You realy don't need a chip change till you start to lose manifold vacuum or your ECM can no longer compensate for added fuel in closed loop.
Instead install an AFPR and 160 deg stat with the MAD fan switch to match and bump base timing a little.
Then you can take the other $100 and do the cut lid and K&N,
Old Jun 7, 2003 | 02:25 AM
BAM92's Avatar
BAM92
If you have a 6spd SLP.com has chips for 69.95 on clearance. Performance gain I would imagine would about be the same as anyone else's if you don't have many mods. But you will get the fans to come on sooner. 70 bucks ain't too bad.
Old Jun 7, 2003 | 06:57 AM
BIG JIM 54's Avatar
BIG JIM 54
I like my ADS chip but my cam needed it.
FWIW,
BIG JIM
Old Jun 7, 2003 | 08:37 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
sent you an im
Old Jun 10, 2003 | 11:03 PM
Black91L98's Avatar
Black91L98
Default Re: Performance Chips (ski_dwn_it)
ive heard people commenting on putting a 160 degree stat - which does what? kick the fans on sooner? with the ultimate goal of keeping the engine cooler? ive read taht the 160 just confuses the ecu, and that the 180 is more workable fora street car...
Old Jun 10, 2003 | 11:33 PM
vader86's Avatar
vader86
Stat only allows it to run a little cooler under normal fan settings. It doesnt affect the fan settings.
In conjunction with lower settings, the car will run substantially cooler. Mine runs between 180-205 oil and 170-185 coolant. With this low temp, i can bump up timing a few degrees for a couple extra HP.
It wont confuse the ECM, the ECM is waiting for it to enter closed loop, which will take longer with the 160 and affects mileage slightly, but it doesnt take very long to enter closed loop unless youre in winter.
Old Jun 10, 2003 | 11:49 PM
Paul T's Avatar
Paul T
Using an Ed Wright fastchip here with a 160 stat.... tried to have one burned for me by a Forum member but after he sent me two different chips burned for my engine (the second time I sent him my stock chip so he could extract the info from it exactly and still couldn't even get the engine to start) I gave up and went with the Ed Wright fastchip and worked perfect right out of the box and hasn't caused me a bit of a problem since... Engine runs great and temps are never higher then 182. Unfortunately I lost money on the first attempt but I figured live and learn... :_dupe:
Old Jun 10, 2003 | 11:50 PM
bikerski's Avatar
bikerski
I have an 86 with auto. Hypertech chip helped the shifting enough to make me happy. Shifting in town was real "luggy". Had to run in D and shift to OD after leaving town. Now can leave in OD all the time. :steering:
To Performance Chips
