a good fuel injector cleaner?
Old Jun 7, 2003 | 10:23 AM
JACKSBLK94's Avatar
JACKSBLK94
Default a good fuel injector cleaner?
i know most cleaners do nothing, but i thought i might try one.....in attempt to solve some problems of hesitation and irractic idle. i am almost 100% certain it is the opti(67k on 94) but i would love to solve the problem with some injector cleaner, maybe i'll get lucky! whats the best brand? thanks
Old Jun 7, 2003 | 10:44 AM
Corvette0096's Avatar
Corvette0096
Default Re: a good fuel injector cleaner? (JACKSBLK94)
http://cruzinperformance.com/
Old Jun 7, 2003 | 10:51 AM
superlund's Avatar
superlund
I have had good luck with either BG 44K or Chevron W/ the Techron additive. At one time the only fuel system cleaner approved for use by Porsche was Techron...
Old Jun 7, 2003 | 11:00 AM
JACKSBLK94's Avatar
JACKSBLK94
Default Re: a good fuel injector cleaner? (superlund)
thanks i will give one of those a try
Old Jun 7, 2003 | 11:09 AM
LarryK 87's Avatar
LarryK 87
Seafoam, Available only at NAPA,
greater than sliced bread
Old Jun 7, 2003 | 11:45 AM
Ericthewolf's Avatar
Ericthewolf
Default Re: a good fuel injector cleaner? (LarryK 87)
seafoam.. although they tell you to only use chevron techron which works well also.. but if you have idle trouble you may want to take our yout idle air control and clean it. There could be build up on it.
Old Jun 7, 2003 | 11:50 AM
scorp508's Avatar
scorp508
Default Re: a good fuel injector cleaner? (corvette0096)
:yesnod:
The only real way to clean them.
Old Jun 7, 2003 | 12:02 PM
sraft's Avatar
sraft
Default Re: a good fuel injector cleaner? (scorp508)
:yesnod:
:iagree:
Cruzin performance did a super job restoring my injectors to like-new condition.
I've read that the injectors in the LT-1 are cooled by flowing gasoline over the solenoid coil, and that certain solvents can harm it. Be careful with the cleaner you put into the gas.
To a good fuel injector cleaner?
