need help
Old Jun 7, 2003 | 10:28 AM
herc's Avatar
herc
5th Gear
Default need help
ok i changed the maf sensor , maf , fuel pump ,tci ,. when i start it it starts then i let it run for an hour and the car stalls out and i start it back up and it fine untill it happens again. if anybody got suggestion let me now thanks
Old Jun 7, 2003 | 10:36 AM
jimswhite92's Avatar
jimswhite92
Default Re: need help (herc)
What model?
Is the ECM giving you any codes when the engine stalls???
Old Jun 7, 2003 | 11:39 AM
herc's Avatar
herc
5th Gear
Default Re: need help (jimswhite92)
yeah 22
Old Jun 7, 2003 | 11:46 AM
ittlfly's Avatar
ittlfly
yeah 22
22= TPS low voltage signal. You may have a bad sensor / connector.
Old Jun 7, 2003 | 11:49 AM
herc's Avatar
herc
5th Gear
Default Re: need help (ittlfly)
and the code for the maf
To need help
