Are these sensor numbers any good?
I'm still trying to diagnose this hard starting problem I've been having. I've been trying to do it step-by-step and slowly eliminate what it could be without spending money on stuff that doesn't need to be replaced.
I did a compression test, and all the numbers came back fine - all 180 to 190psi. I conducted a fuel system pressure test (at the fuel rail) and everything looked ok there too. So it's not low compression and it doesn't seem to be fuel related.
I finally got around to testing my TPS and Coolant Temp Sensor. And here's the numbers:
CTS: 2.07Kohms @73degF (ambiant) and 53% humidity
TPS: 0.49V@closed throttle position; 4.45V@W.O.T.
Do these numbers seem right to anyone out there? The car is a stock '89 L98 by the way.
The TPS number seems a little low, but within GM specs (0.54V+-0.08V); I have no idea if the coolant temp sensor is reading ok or not.
So if these number are OK, then it looks like it may be an ignition problem. Anyone know how to test an HEI coil for proper output?
Thanks in advance.
The TPS is a little low, set it to .54-.65Vdc at base idle of 450rpm (with IAC pintel fully extended).
BTW, what trouble symptom are you checking?
I'm still stumped. I've even tried disconnecting my MAF and starting the car to see if that solved the problem, but it didn't. The only thing I haven't tested yet is my ignition system. I've set the timing to 6degBTDC and I'm sure that it's OK, but I don't know how to test the output from the coil.
[Modified by TheCorvetteKid, 10:53 PM 6/7/2003]
Since you have an '89 L98 cold starting issues cannot be due to the 9th injector; but have you checked fuel pressure and verified that the fuel rail holds a prime after you turn on the ignition, before starting the engine?
You might also verify that the coolant temp sensor (the one under the TB) resistance changes with temp change. I don't know the exact values but resistance should drop as temp increases.
I thought that 38psi at idle was alittle low, but from everything I've read and seen, this is actually normal. I should probably mention, I don't have an adjustable fuel pressure regulator - my car is pretty much stock with the exception of a few usual things (K&N, cut MAF screens, 1.6 roller-tip rockers, and no frisbie).
Thanks for the tips. I'll check your site and see if adjusting the TPS voltage will make any difference. Someone suggested swapping out my ECM to see if it may be at fault. I have a new unit here still in the box. Maybe that'll do it.
[Modified by TheCorvetteKid, 9:03 AM 6/8/2003]
