Electronic A/C problem
Old Jun 8, 2003 | 05:48 PM
Larrym96815's Avatar
Larrym96815
Default Electronic A/C problem
The electronic A/C on my 91 just stopped blowing cold air. The blower runs but the compressor clutch does not engage. I had the freon level checked and it is okay. The light on the dashboard above my A/C "on" switch is now flashing instead of staying green. Any help appreciated.
Aloha,
Larry
[Modified by Larry Mackey, 12:36 PM 6/8/2003]
Old Jun 8, 2003 | 06:54 PM
don hall's Avatar
don hall
Default Re: Electronic A/C problem (Larry Mackey)
The flashing light means "trouble code(s)" are stored.
To retrieve codes: push and hold the fan "up" arrow and the fan "down" arrow at the same time for 5 seconds. The LCD will show "00". Push "auto fan" and the LCD will show codes that are stored. The most common is 09 - low freon. Post the codes, and we will help.
Old Jun 8, 2003 | 07:34 PM
Larrym96815
Default Re: Electronic A/C problem (Oldman)
Thanks, I will try it. Should the key be on or off when pushing the buttons?
I actually read the owners manual and it says to pull #1 and #17 fuse and it will reset. I tried it and it worked. I will still try to read the codes though, thanks again.
Aloha,
Larry
Old Jun 8, 2003 | 07:43 PM
don hall's Avatar
don hall
Yes, ignition "on".
When you push the "Auto Fan" button, and the LCD still displays "00", that means that there are no trouble codes stored.
Old Jun 8, 2003 | 08:29 PM
Jerry D's Avatar
Jerry D
I have the same exact problem but I don't know if my freon is up to the right level.
To Electronic A/C problem
