3.33 gears?
Old Jun 10, 2003 | 01:30 AM
vetteguy216's Avatar
vetteguy216
Default 3.33 gears?
I have 2.59's and want change. 3.54's are too much 3.07 are not enough and 3.33's are just what I want. :yesnod:. Do you guys know where I can get these and show much they will help my 1/4 times.
Old Jun 10, 2003 | 08:09 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: 3.33 gears? (vetteguy216)
FWIW I don't know if you can drop 3.33's into a Dana 36 because the 3.33's were standard on Dana 44 equipped cars.
Sorry, I don't know where the best place to buy 3.33's is but thought I'd mention the diff housing issue incase.
Old Jun 10, 2003 | 08:26 AM
black bart's Avatar
black bart
Since you ask about times it soumds like you are going to drag race so instead of changing gears change the whole thing a 44 will have the 3.33 gear set in it and it is a lot stromger. Money spend on a 36 to drag race is a waste of time and money
Old Jun 10, 2003 | 08:35 AM
tuband's Avatar
tuband
Cruise-In I Veteran
Good news :D and bad news :sad:
There were 3.31 gears available for the D36. I've heard differing stories on whether they existed as a factory option for one year or only as an option that was ordered for switching to. At any rate they were available directly from GM and are an excellent gear choice for anyone not wanting to go as high as a 3.54 or 3.73. I know, because I changed my 2.59s to the 3.31 gear set.
Bad news is they are HARD to find and were discontinued a number of years back. I suppose it's possible to find a ring/pinion just sitting in a dealer's parts bin somewhere, but otherwise you'll need to hope that a Vette owner with a 3.31 rear is wanting to change over to something else. I looked for over a year before I found a complete D36 with 3.31s.
Another option is to switch to the D44 .... stock gears are 3.45 which is pretty close. And the 3.07 is not a bad gear choice plus it's more readily available.
Good luck on your search.
Old Jun 10, 2003 | 09:23 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: 3.33 gears? (tuband)
My 89' 6spd was D44 3.33. I'd find one in a salvage yard and swap the whole thing... :smash:
Old Jun 10, 2003 | 10:28 AM
vader86's Avatar
vader86
3.3x was available in 84s, which were all D36s.
You dont really need lower than 3.07, if you want to drop your times, buy a torque converter with about 2000-2200 stall (if you drive it daily, up to 2400 for a more serious drag car that gets occasional use).
Old Jun 10, 2003 | 11:41 PM
jimtreber's Avatar
jimtreber
I had the exact same thoughts as you. I spent months looking for a 3.36/3.31 set for Dana 36 and finally found it at Motive Gear. But, alas, it would only fit a case that had 3.07 or numerically higher to start with. So I settled for a complete 3.07 rear and got a great deal on a 9000 original mile unit. It made a nice difference but for the street I think I would have been happier with the 3.31. Mine's a stock '88 except for a 2500 converter.
[Modified by jimtreber, 4:43 AM 6/11/2003]
Old Jun 12, 2003 | 02:19 AM
vetteguy216
Default Re: 3.33 gears? (jimtreber)
So you can only buy the 3.33's from a private party not a retailer.
Old Jun 12, 2003 | 12:17 PM
vader86's Avatar
vader86
You currently have a 2-series carrier now, you will have to get a 3-series carrier and get the 3.33 gears to convert.
Old Jun 12, 2003 | 05:02 PM
dgoodhue's Avatar
dgoodhue
You won't find 3.31 laying around at a dealership, they were discontinued in 88 if I remember right.
Old Jun 12, 2003 | 05:30 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
steve: I have a whole dana36 pumpkin with new 3:31 gears
that fit 1984 - 1987. $475.00 = shipping.
if interested e-mail me at rpdlt@aol.com :chevy
[Modified by Vette Ed, 5:36 PM 6/12/2003]
To 3.33 gears?
