vette hard start !@#$%^&*(
Senior Member
29 posts [100%]
Inman SC
88 hard to start - !@#$%^&*( 1:33 PM 6/8/2003
I continue to have a hard to start problem when my C4 is cold. I thought it would be the fuel pressure but checked it yesterday and it jumps almost to 40# and holds for hours afterwards. So, not that I don't think!
I noticed that when I pulled the plugs last, they were pretty gunked up like it is running very rich. Any ideas.
I did a search on the archives but they seem to focus on the fuel system. Mine seems fine. Could it be the ECM and how do I check it. Any ideas will be very appreciated.
billyjack
ciscokid
Senior Member
74 posts [100%]
West Sacramento CA
Re: 88 hard to start - !@#$%^&*( (billyjack) 3:40 PM 6/8/2003
You might want to check your Cold Start valve and sensor. The cold start valve introduces extra fuel while cranking the engine and is independent of the ECM and based on your starting system.
vetracer
Senior Member
440 posts [100%]
chandler AZ
Re: 88 hard to start - !@#$%^&*( (billyjack) 6:02 PM 6/8/2003
What is it doing? Is it firing at all?
65Z01
Cruise-In II Veteran
8496 posts [100%]
Blauvelt NY
Re: 88 hard to start - !@#$%^&*( (billyjack) 6:22 PM 6/8/2003
Also check the coolant temp sensor in the block under the TB; that's the one the ECM uses to establish closed loop mode.
You can use a paper clip and the test method on my site to see if the ECM is going into closed loop.
billyjack
Senior Member
29 posts [100%]
Inman SC
Re: 88 hard to start - !@#$%^&*( (vetracer) 11:51 AM 6/10/2003
Thanks for the help. Yes the car is firing but acts like its starving for gas. It will finally start but takes a while if the battery holds up. Almost like the choke isn't working which it isn't because it doesn't have one. I thought of the cold start injector but read where some folks are taking it out all together since it only works below certain temps which is not the case here in SC. Any ideas????
billyjack
» Return to C4 Tech/Performance Forum Jump 50th Anniversary Events Audio/Electronics Autocrossing & Roadracing Breathless Performance C1 & C2 Corvettes C1 & C2 Parts C1s & C2s for Sale/Wanted C3 Corvettes C3 Parts for Sale/Wanted C3s for Sale/Wanted C4 Forced Induction/Nitrous C4 General Discussion C4 Parts for Sale/Wanted C4 Scan & Tune C4 Tech/Performance C4s for Sale/Wanted C5 Forced Induction/Nitrous C5 General Discussion C5 Parts for Sale/Wanted C5 Scan & Tune C5 Tech/Performance C5s for Sale/Wanted C6 General Discussion Car Care Products Corvette Accessories Corvette Babes Corvettes of Houston Cruise Control Auto Die Casts & Collectibles Drag Racing Engine Mods Exit 28 Motorsports F-Body General Discussion Factory Correct Resto Funny Off Topic Threads Great Lakes Help Forum Ken's Newsletters LAPD Moderator's Corner Mountain - Prairie National Events Northeast Off Topic Other Cars Other Country Events Pacific Politics & Controversy Regional Coordinator's Forum Southeast Southwest T Byrne Motorsports Testing The Boneyard West Coast Corvettes Wheels & Tires Xtreme Motorsports Z06 Discussion Zip Products Section ZR1 Discussion
Powered by zeroforum 2.0.5. ©2002 zeroforum.com.
:flag
