Replacing the ABS pump and brain...
Old Jun 10, 2003 | 10:53 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Replacing the ABS pump and brain...
can it be done at home or would it be better to get it done by a mechanic???
What work is involved?? Are any special tools needed??
Thanks in advance
Old Jun 10, 2003 | 11:23 AM
John Row's Avatar
John Row
Default Re: Replacing the ABS pump and brain... (GrandSportC3)
You can probably do it at home, but you would have no way to test it properly unless you have access to a TECH II.
Old Jun 10, 2003 | 11:31 AM
GrandSportC3
Default Re: Replacing the ABS pump and brain... (John Row)
What you mean by testing it??? Can't I just try to lock up the brakes to see if the ABS works??
Old Jun 10, 2003 | 02:04 PM
John Row's Avatar
John Row
That seems a bit risky to me, what if it doesn't work? If it does seem to work, how would you know you locked up all four wheels.
Also, the ABS is an integral component of the ASR package.
The CCM will force the ABS to do a basic test as soon as you get above 3MPH. What is your plan when it sets a code? (It probably will.)
Old Jun 10, 2003 | 02:15 PM
GrandSportC3
Well - I get a code right now.. That's why I'm replacing the unit...
Does anyone have instructions on what work and tools are involved in the swap???
Old Jun 10, 2003 | 05:11 PM
GrandSportC3
ttt
Old Jun 11, 2003 | 11:14 AM
John Row's Avatar
John Row
What code(s) are you getting now?
Old Jun 11, 2003 | 06:55 PM
c4cruiser's Avatar
c4cruiser
I think the tools may be pretty straighforward. Line wrenches of the proper size for the brake lines and whatever it may take on the attaching brackets and the electical connectors just pop off. You will have to have a Tech 1 or 2 with the brake module to energize the new ABS unit to properly bleed the system. I don't think you can get fluid into it and (the air out)by just bleeding the brakes at the calipers.
Old Jun 12, 2003 | 10:23 AM
GrandSportC3
I don't have the analyzer.. but my mechanic said that the code indicates that the pump is bad...The light only comes one when you start driving.. When turning on the car - the ABS/ASR light doesn't come on until I start driving..
[Modified by GrandSportC3, 10:26 AM 6/12/2003]
Old Jun 12, 2003 | 10:25 AM
GrandSportC3
Default Re: Replacing the ABS pump and brain... (c4cruiser)
Thanks!!! :thumbs: :thumbs:
Old Mar 8, 2021 | 09:04 PM
Elijah Rodriguez's Avatar
Elijah Rodriguez
How did it turn out?
Old Mar 8, 2021 | 09:22 PM
Beater12's Avatar
Beater12
I'd like to know too but since the thread is 18 years old I don't think we'll get get a response.
Old Mar 8, 2021 | 10:18 PM
GrandSportC3
WOW - Holy thread resurrection.. I did NOT do it.. I sold the car without fixing it.. gave the buyer the replacement part..
Old Mar 8, 2021 | 10:42 PM
Beater12's Avatar
Beater12
Well I guess you made a liar out of me LOL! I have one wheel locking up and pretty sure it's the ABS pump. Have an appointment next week and will post the results.
Old Mar 8, 2021 | 11:47 PM
GrandSportC3
I frequeny search for my username to bring up threads that I participated in to look for new replies.. Didn't expect a 18 year old thread to come up..
Old Feb 21, 2022 | 10:20 PM
Karenldm's Avatar
Karenldm
Hey, let's resurrect this thing one more time! LOL! My mechanic told me I needed a new ABS pump for my 1986 Corvette, but he's not sure where to get one or even a refurbished one ( he said definitely don't get a used one because apparently this was a common problem with the C4). What did you find out in 2021? It's my driver side front locking up.
Old Jul 13, 2022 | 04:43 PM
The Thomas J's Avatar
The Thomas J
bumping this thread AGAIN! My mechanic has just informed me that the rear brakes on my car are locking up and I need a new ABS pump. I am debating if I should just bypass the system altogether and be done with this issue once and for all. Can it be done, and where can I find the ABS pump? I haven't been able to locate one.
Old Jul 13, 2022 | 08:33 PM
GrandSportC3
I found one on Ebay. You can also try Car-Part.com--Used Auto Parts Market
Old Jul 15, 2022 | 06:02 PM
Karenldm's Avatar
Karenldm
I had two mechanics strongly recommend that I do not bypass the system! I found my ABS pump on eBay, and so far, all is well! Good luck!
To Replacing the ABS pump and brain...
