'95 lt1 question
Old Jun 11, 2003 | 12:56 AM
loflite's Avatar
loflite
Default '95 lt1 question
Is the VIN stamped on the '95 block anywhere like the C3's? It's not on the passenger side pad. Thanks.
Old Jun 11, 2003 | 12:59 AM
BAM92's Avatar
BAM92
Default Re: '95 lt1 question (loflite)
I believe, and I very well could be wrong on this one, the VIN is only on the driver side dash. And no where else on car.
Old Jun 11, 2003 | 01:33 AM
Ericthewolf's Avatar
Ericthewolf
Default Re: '95 lt1 question (BAM92)
The engine is stamped with a partial VIN it has 9 positions. The first is the GM division identifier IE chevrolet. The second is the year S=1995. Third is Assembly plant IE bowling green, KY. Four through nine give you the vehicles sequence number like it was the 345th car etc. There should also be a stick on lable , laser etching or stamp on the block with eth engine unit number or build date code. The vin should be right in front of the passenger side valve cover on the block underneath your ignition coil..
Old Jun 11, 2003 | 01:38 AM
loflite's Avatar
loflite
Default Re: '95 lt1 question (Ericthewolf)
My pad under the ignition coil is blank except for the engine suffix ZUC.
[Modified by loflite, 9:00 AM 6/11/2003]
[Modified by loflite, 9:02 AM 6/11/2003]
Old Jun 11, 2003 | 10:02 AM
loflite's Avatar
loflite
TTT
Old Jun 14, 2003 | 08:33 PM
loflite's Avatar
loflite
ttt :confused:
To '95 lt1 question
