Clunking noise from rear
Old Jun 11, 2003 | 12:40 PM
Lichen's Avatar
Lichen
Default Clunking noise from rear
The only time I notice the clunk is when I am going slow on a paved road with small bumps. As I go over the bump, there is a distinct mid-pitch clunk coming from the left rear wheel area. Any ideas?
Old Jun 11, 2003 | 03:43 PM
funky87vette's Avatar
funky87vette
Cruising
Default Re: Clunking noise from rear (Lichen)
I'm not sure for a Corvette, but I had a similar problem in a different type of car. The spare tire was low on air and rattling around inside the brace. Pull down your spare and make sure it's inflated perhaps?
If that's not it, I have no idea. I hope that helps.
Old Jun 11, 2003 | 04:58 PM
vader86's Avatar
vader86
Probably a loose shock mount if its related to road bumps. Or a loose bolt somewhere.
Old Jun 11, 2003 | 07:35 PM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: Clunking noise from rear (vader86)
Could be UJOINT, Location: driveshaft or rear axle.
[Modified by 92LT1Roadster, 6:36 PM 6/11/2003]
To Clunking noise from rear
