Brake Upgrade Suggestions
Old Jun 11, 2003 | 12:47 PM
ncccracer1986's Avatar
ncccracer1986
Default Brake Upgrade Suggestions
As I'm sure many of you are aware, the brakes on the 84 - 87 vettes are nowhere near adequate for racing applications.
I am needing a budget brake upgrade that will at least take me to the 88 - 96 brakes.
I know that Doug Rippie sells the adapter brackets for this,
but was wondering if anyone knew of any other companies that sold these?
Also, any other brake upgrade suggestions are appreciated.
Thanks,
Scott
[Modified by ncccracer1986, 5:48 PM 6/11/2003]
Old Jun 11, 2003 | 01:14 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Brake Upgrade Suggestions (ncccracer1986)
Since you say budget, I assume you don't want to lay out any extra cash for rims or spacers or anything like that. Problem is if you're still running the 86 rims you are going to have to upgrade the rims.
So what rims do you have on your car?
Old Jun 11, 2003 | 03:00 PM
ncccracer1986
Default Re: Brake Upgrade Suggestions (Jeffvette)
Am running 17" X 11" 5 spoke ZR1 rims
Old Jun 11, 2003 | 03:45 PM
Jeffvette's Avatar
Jeffvette
In that case, for the 84-87 guys I recomend that you go with the C5 kit.
Get ahold of Chris May at Superior Chevrolet for most of the parts you need. I'll email you a link for a place to get the brake adapters for a decent price....around 175 for the pair.
Old Jun 11, 2003 | 03:56 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
I agree with Jeffvette........
But I know where you can get the brackets for quite abit cheaper......
http://forums.corvetteforum.com/zerothread?id=581163
Old Jun 11, 2003 | 04:00 PM
ncccracer1986
Default Re: Brake Upgrade Suggestions (edsalinas)
Jeff,
Please email that link to scottm@tlitech.com whenever you get the chance.
Shouldn't have a problem getting the other parts, my father-in-law owns a GM dealership.
I can get any parts I need for little over cost.
Thanks,
Scott
Old Jun 11, 2003 | 04:04 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Ed, from your thread...I don't think the regular C5 calipers are any cheaper, because they're exact same part but red instead of black, and so the color, not the guts of the caliper, are what require the different P/N, but memory tells me that the price is the same.
Also, for those who might be interested, I'm going to be taking my car off the street soon, and so my stock 16" wheels are gone, finally allowing me to put my Wilwoods on. Initially I am going to be using the Superlite IIA calipers (4 piston, 1.75" pistons) w/ C5 rotors. These calipers run ~$200 each brand new, and the rotors are another $110-200 depending on your sources (typically, you have to have a friend at GM to get the rotors for $55 each...I got mine for $48 each), and I will have the plans for the adapter bracket for the SLIIA calipers, so if people want them, I should be able to accomodate.
Old Jun 11, 2003 | 04:07 PM
Jeffvette's Avatar
Jeffvette
Jeff,
Thanks,
Scott
Sent Scott.
Old Jun 11, 2003 | 04:22 PM
edsalinas's Avatar
edsalinas
Default Re: Brake Upgrade Suggestions (CorvetteZ51Racer)
Ed, from your thread...I don't think the regular C5 calipers are any cheaper, because they're exact same part but red instead of black, and so the color, not the guts of the caliper, are what require the different P/N, but memory tells me that the price is the same............
Actually, I just verified with a couple sources, the unpanted calipers are a little more than the red ones, figure that one out ? ?
:crazy: :crazy: :crazy:
To Brake Upgrade Suggestions
