Would changing my stock injectors to a larger size and/or adding an adjustable fuel pressure regulator actually improve performance?
Things I have done:
Porting work to the plenum and base
Hypertech coil kit
Fresh (cut) plugs and wires
Done before me:
Hypertech chip (already installed when I got the car)
Borla cat back (installed when I got the car)
K&N filter (already installed)
Porting the plenum and base probably was the one thing that gave me the most "seat of the pants" feel of improvement. I would highly recomend this. And it doesnt cost hardly anything.
I don't think the AFPR will help any. The computer will adjust the A/F ratio based on the O2 sensors. It will "learn" that you run rich and adjust the pulse width accordingly. JMHO
Plugs and wires (if the ones you have are getting old) is one of the best "bolt on mods"
