Does hotter spark = faster C4?
Old Jun 11, 2003 | 04:33 PM
funky87vette's Avatar
funky87vette
Cruising
Default Does hotter spark = faster C4?
Hello.
I did a search and found no help on this topic... I have an '87. I noticed something the other night while working on the car. It has the same rotor, distributer cap, wires, and plugs that came with the car I think (I bought it used). I looked at the plugs and they're a nice tan/brown color, so they're burning clean and the car idles and runs smoothly...
My question: Is it worth it to buy a "Davis Hi-Voltage" coil, cap, and rotor ($100), a set of high quality wires ($70), a set of platinum plugs ($30), and DynaMod high performance ignition module ($80) from Ecklers (or whoever)?
It seems to burn clean and idles smooth. I see no need to replace what's there unless people on the forum agree that it's a worth while upgrade. Thanks for all your help guys (and gals)!
[Modified by funky87vette, 5:03 PM 6/11/2003]
Old Jun 11, 2003 | 04:35 PM
MrNuke's Avatar
MrNuke
Default Re: Does hotter spark = faster C4? (funky87vette)
I don't think you will need it unless you modify the engine..
It might give you a better combustion if you switch to a better ignition system, mayeb slightly better fuel economy, but more power? I don't think so unless you are already having problems..
Old Jun 11, 2003 | 04:39 PM
vader86's Avatar
vader86
The stock HEI ignition is one of the things GM did right with the L98. There is really no need to modify it unless you modify the engine, but I would get good plug wires anyway. Coil/Cap/rotor stock stuff is fine.
Old Jun 11, 2003 | 06:02 PM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
:iagree:
Personally I like stock GM stuff, but thats just me.
How bout a pic of your 87?
:cheers:
Old Jun 11, 2003 | 11:52 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: Does hotter spark = faster C4? (sgt538)
Unless you run a highly modified car with nitrous or boost or some type of big cam that generates really high cylinder pressures you have no need to go with a whole lot of aftermarket stuff. I'd upgradw wires and thats about it. The GM stuff is pretty darn good till you get exstensive mods.
Old Jun 12, 2003 | 09:09 AM
funky87vette
Cruising
Here's a pic for you! :-) Thanks for the advice guys!
Old Jun 12, 2003 | 11:06 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Nice looking '87 you have there! :thumbs: :cheers:
Old Jun 12, 2003 | 11:16 AM
Strick's Avatar
Strick
Is that "Meltdown Island?"
To Does hotter spark = faster C4?
