I have a 1991 and the cooling fan problem. If I turn the A/C on the fan comes works. Is the the Aux fan? I recently replaced the coolant sensor (under the t/b). Is this the one that controls the fan? or is there another one that controls the fan. Am I wrong in assuming that the relays are ok if the fan comes on with the A/C? Thanks for the help.
Niether sensor really controlls the fan, the ECM controls them. A couple of questions:
1. Why did you have to replace the sensor?
2. What temps are you expecting the fans to turn on?
If turning on the A/C turns both fans on, then the control circuitry is working properly. The only other thing to look at is the "Fan Request" from the ECM, but you'll need a scanner to do that (like Diacom).
230 degree is the set point for the first fan. and the second is a little higher. When you run the ac the fans come on to cool the condenser, regardless of engine temp.
I replaced the sensor becuase the Temp gage quit working, then I realized that the sensor for the gage is on the right side of the engine, and the wire was off. (must have bumped it when I changed the plugs and it vibrated loose) Now the temp gage works again. I have a hypertech chip installed along with a 170 degree thermostat. This has been in the car for the last couple of years with no problems.
Thanks for the help! and I'm glad I joined the forum
Ok, I'm stepping just a bit outside my league now, I'm not a L98 guru. I'm going to defer to the more experienced now.
I'm just not sure if the later L98 engines used a temp switch or the ECM (LT1's used the ECM to control all aspects of fan control).
