Stage II ....... what do you think?
Old Jun 12, 2003 | 12:01 PM
Sliding's Avatar
Sliding
Default Stage II ....... what do you think?
I finally received parts that I've ordered to complete stage II modifications
as I planed.
What HP numbers should I expect with this mods?
( stage I mods are in sig. )
Here are the parts:
- LPE 74219 cam
- comp cams valve springs
- LPE titanium retainers
- hooker supercomp headers
- Accel adjust. fuel press. reg.
- comp cams double roller timing chain set
- I will also do some serious heads porting and polishing
Old Jun 12, 2003 | 12:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Stage II ....... what do you think? (Sliding)
I think your potential gain is about 70hp.
Old Jun 12, 2003 | 01:36 PM
Zix's Avatar
Zix
Default Re: Stage II ....... what do you think? (65Z01)
Add some 1.6 rockers on there as well...but it seems that your limiting factor now is going to be the TPI intake. Are you going to do any work on the runners to try to increase flow?
Old Jun 12, 2003 | 03:09 PM
Sliding's Avatar
Sliding
Default Re: Stage II ....... what do you think? (Zix)
I have allready ported stock TPI as much as it can go. I have also siamesed
plenum and I'm thinking of siamesing intake base at this point.
1.6 RR and Superram should be stage III next year if everything will be O.K.
To Stage II ....... what do you think?
