Transmission Leak
Old Jun 12, 2003 | 02:38 PM
87Vert's Avatar
87Vert
Default Transmission Leak
I've got an 87 automatic with a transmission leak. I think the leak may be at the joint between the fill tube and the case. When I was replacing plugs/wires, and new valve cover gaskets the fill tube may have gotten jostled around a bit. There appears to be a rubber gasket at the base of the fill tube. Does anyone know if this can be repaired without taking the whole darn car apart?? :confused:
Old Jun 12, 2003 | 03:39 PM
Rick86's Avatar
Rick86
Default Re: Transmission Leak (87Vert)
The fill tube is secured to the transmission by one of the bolts that holds the transmission t the engine. Remove that bolt and the fill tube can be pulled out from the top, and the rubber seal can be replaced.
Old Jun 13, 2003 | 10:36 AM
87Vert's Avatar
87Vert
Default Re: Transmission Leak (Rick86)
Thanks! I'll give that a try!!
Old Jun 13, 2003 | 09:11 PM
Stingray1970's Avatar
Stingray1970
If you choose to by the seal from GM the pn is 1259475 fits 84-91
Old Jun 14, 2003 | 01:53 PM
VetteTech81's Avatar
VetteTech81
Sounds Easier then it is... lots of moving and wiggleing to get that sucker in or out...
Old Jun 16, 2003 | 03:26 PM
87Vert's Avatar
87Vert
Default Re: Transmission Leak (VetteTech81)
Thanks for the part number and the warning!! I'm finding that repairing many things aren't as easy as they appear they might be.
Old Jun 17, 2003 | 10:55 AM
VetteTech81
Yup... welcome to my world...
To Transmission Leak
