Rim Polishing - 1st One Complete - WOW!!!
I tell ya, I was VERY nervous about starting this project but boy am I glad I did it now!! I'm very pleased with the results of my efforts.
If I could give a couple of words of advice to anyone who is going to take this on they would be...
1. Take your time!! It will take hours per wheel to get a good finish.
2. Dont' stop at 400 grit paper like some tell you to do. Go fine enough until you can't see ANY fine scratches. I tried buffing at each step and decided to continue until I had a mirror finish. If I had some fine cut compound handy I would have used it before the polish step.
I've got one more wheel to do tomorrow then I'm done. Whew!
http://www3.ns.sympatico.ca/krichar/rims/rims.htm
:party:
:party:
Re: Rim Polishing - 1st One Complete - WOW!!! (FoolCrzy)
looks good but you can do better than the mothers polish...........I did exactly the same as you on my intake runners but wasn't happy with the shine so I went to a local chrome shop and asked what they used.........I don't know the name of the stuff but its like a hard wax.........you just run your buffer against it and then buff the part...........looks like it was chromed........check out my sig
St. Jude Donor '05
Re: Rim Polishing - 1st One Complete - WOW!!! (Atok)
Very nice! :cool:
I cut out all the hard work and just bought new wheels instead. :D
Re: Rim Polishing - 1st One Complete - WOW!!! (Blueyednd)
So you are using sand paper?
There is a much easier an less painful way of polishing...
I would go with cloth discs and polishing compound found in the tool section of Home Depot that you use with a drill. I used a bar of the red (fairly course) to take off the paint and a bar of the white as a final polish. It looked like chrome when I was done and it lasted that way for two years until I sold the car I did it to... I did keep on top of them however to keep the brake dust and grime off of them however.
I am going to setup one of the CNC's at work to do the polishing for me sometime this summer... Totally painless :)
looks good.
I like the polished look better than chrome.
Do you plan on doing anything special to protect them? (clear cote?) :thumbs:
Re: Rim Polishing - 1st One Complete - WOW!!! (Phil-tha-Rush)
No, I'm not planning to clear coat them, don't want to dull the shine! :) I don't drive the car in the rain (normally) or salt, etc. so I just plan to give them a quick clean and polish every month or so. Also I plan to keep a coat of wax on them.
Or...A guy at a car show showed me some stuff that puts some sort of oxide coating over aluminum. It doesn't duff the shine and protects the rim. I may look into that stuff. His rims looked A1 with the stuff applied.
To answer someone else's question...Yes, the wheel is on the wrong side of the car. I had more light on the driver's side so I just stuck it on that side to get the pictures.
:cool:
:cool:
Nice Job.
:thumbs:
Whne you started, where they the rough (91,92 - I think) or the polished wheels to begin with?
[Modified by shansen, 12:19 PM 6/13/2003]
[Modified by shansen, 12:20 PM 6/13/2003]
:thumbs:
Re: Rim Polishing - 1st One Complete - WOW!!! (shansen)
They are '95 rims, not really polished, they seemed to have some sort of an anodized coating under the clear coat which makes them shine. 75% of the work was sanding the machining grooves out of all the corners.
Re: Rim Polishing - 1st One Complete - WOW!!! (honas)
________________________________________ ___
Where is your sig?????
:iagree:
This is one of those projects I've been putting off because of the work vs. rewards ratio.. If you've got a nice side pic of the whole car with the wheels complete I'd likely be convinced...
Thanks!
[Modified by PoloGrnC4, 3:21 PM 6/14/2003]
:iagree:
Thanks!
Re: Rim Polishing - 1st One Complete - WOW!!! (PoloGrnC4)
