High speed engine cut out
Old Jun 13, 2003 | 05:43 AM
DrVette's Avatar
DrVette
3rd Gear
Default High speed engine cut out
On a long hard run, my 86 starts to misfire, and sometimes cuts out completely. This can be pretty scary! When I pull over, and lift the hood there is a lot of heat there, and after a few minutes, it'll startup ok again. The coolant temp never goes over 200, and oil temp is ok too. Plugs, leads, cap and coil have all been changed. I recently put in new injectors and seals, but it's just done it again. I'm not getting any codes. Any ideas?
Old Jun 13, 2003 | 07:56 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: High speed engine cut out (DrVette)
Check for plugged cats/pre-cats. Worth a shot.
Old Jun 13, 2003 | 11:13 AM
ittlfly's Avatar
ittlfly
I'd look real hard at the coil. They tend to crap out under heavy load if their going bad.
Old Jun 13, 2003 | 01:20 PM
DrVette's Avatar
DrVette
3rd Gear
Default Re: High speed engine cut out (ittlfly)
I changed the cat last year, so it should still be good. I'm getting fluctuating idle when hot also. I was thinking maybe fuel pressure regulator or MAT sensor?
Old Jun 13, 2003 | 01:54 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Hmmmmmmmm maybe someone put a ping pong ball in your gas tank.
Old Jun 13, 2003 | 03:35 PM
GusBustamanteJr's Avatar
GusBustamanteJr
I would also look real hard at the coil......
I had a similar problem twice. The first time, the crummy Hypertech Rotor had come loose.
Second time, the lead to ECM from the Distributor was loose.
Double check all the ignition components, or try to find that ping pong ball.
To High speed engine cut out
