Radiator Repair?????
Old Jun 13, 2003 | 10:59 AM
jerkyboy's Avatar
jerkyboy
Default Radiator Repair?????
Hey all. I am building up a heads/cam engine and want to know
1) Can the stock '89 radiator handle 400 hp?
2) Can one of these radiators be repaired properly - I have a leak from the lower corner, I just havn't identified if it is the plastic part or the Aluminum
I am installing a new waterpump while the radiator is out and a new 160* T-stat. I would like to save the $$
If the answers to the above are "no", what are you all using and how much did you pay? THANKS!
Old Jun 13, 2003 | 12:19 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Radiator Repair????? (jerkyboy)
If the radiator and cooling system are in excellent shape, and have been well cared for should have no problems.....here's an idea...Run a FlowKooler water pump...and add some waterwetter....
Should be fine...
tony
:cheers:
Old Jun 13, 2003 | 12:25 PM
jerkyboy's Avatar
jerkyboy
Default Re: Radiator Repair????? (oldace84)
Thanks Tony. I did order a Flowkooler waterpump. I've never heard of it until I read about a couple of people using them on the forum. So I took a chance and ordered one!
Old Jun 14, 2003 | 10:58 AM
BIG JIM 54's Avatar
BIG JIM 54
Hi JB,
I'm running about 325-330HP according to the Desktop Dyno 2000. And without the thermo I cruise down the freeway running about 150F this time of year in CA. Seldom do the fans come on unless I'm sitting in the drive-thru at a fast-food joint.
But your car is old enough to just get a new radiator the way I did. It's about $120-$130 on the Net. A radiator repair shop will charge you $100 to take the end caps off, repair your leak, clean the aluminum core and put it back together. A ban-aid would be to just run a can of stop-leak if the leak is small.
olderace84, Are your wheels genuine Gotti's?
FWIW,
BIG JIM
[Modified by BIG JIM 54, 8:01 AM 6/14/2003]
Old Jun 16, 2003 | 08:35 AM
jerkyboy's Avatar
jerkyboy
Default Re: Radiator Repair????? (BIG JIM 54)
Big Jim, since I am spending mucho $$ already, I decided on a good replacement. I looked all around and ended up talking to Dewitts. They are custom making me a two row for the same price as a Griffin.
To Radiator Repair?????
