84 dig. dash to a analog
Old Jun 14, 2003 | 03:38 AM
Cory00's Avatar
Cory00
Default 84 dig. dash to a analog
ok this is my new project i wanna do i got a 84 with the digitial speed. and tach. the hole 9 yards well i want to convert every thing to analog gauges. i want a speed. that goes to like 180 or 200 instead of 85 and all that cool stuff. im tired of it looking like a video game plus the cluster does not work. would this be easy to do like a weekend project if so what would i need to do this. woudl it really be hard to do
thanks for the help
sorry about the spellings kinda late
Cory :auto:
Old Jun 14, 2003 | 04:48 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: 84 dig. dash to a analog (Cory00)
I have thought about doing the same thing...and awhile back I saw an article with pics and everything about the same thing....but I can't remember where I saw it for the life of me...if I think of it, I will post it!
Old Jun 14, 2003 | 09:04 AM
SBNova's Avatar
SBNova
Default Re: 84 dig. dash to a analog (Bruthish)
I have the same idea. I saw the thread your talking about with the link, but that person used aftermarket guages- and I dont think they were nice ones if I recall. The problem with the swap is that the brain for the cruise control is in the cluster- so it wont work after the swap. The other thing is that the cluster half's the signal from the tranny's speed sensor and sends it back to the ecm. I cant find out exactly what it needs this info for except for maybe converter lock-up. So my thought was to use a cactory type cluster- and the 3rd gen Camaro is almost perfect in size and shape. But the up to 1990 they had mechanical (cable) speedos, only the 90,91 and 92's had electronic. I bought one of those and started to figure it all out but I havent finished yet.
The simple things work like the directionals, check engine light etc, but the tach was reading funny- jumping and seemingly the wrong rpm. I bought it on ebay and the guy said it was a V8 car, but you never know when you buy it used like that. I know the cuise still wont work but I was hoping the cluster would have the speed signal feedback Im looking for.
I hope to get it working because the size and shape are nearly perfect. The bad thing is that it is roughly a 110 mph speedo and the higher mph units (with elec speedo's) are signifigantly more $ and harder to find. Let me know what you find and maybe we could collaborate to get something working.
Old Jun 14, 2003 | 09:58 AM
hngacurv's Avatar
hngacurv
You can find some info on the conversion here. http://www.batee.com/corvette/index.shtml
Old Jun 14, 2003 | 02:06 PM
nobodyunknown's Avatar
nobodyunknown
I repaired my digital dash myself.Its easy,all you do is tear it apart & solder everything.I put on magnifying glasses & I could see all the broken solder joints.Really dont be imtimidated by it.Its as basic as changing spark plugs.
Old Jun 14, 2003 | 03:04 PM
FD2BLK's Avatar
FD2BLK
I was thinking of doing a similar swap but decided to buy a cluster instead. I got one off e-bay for $290. If you are considering it what I was going to do is remove the old cluster use it as a template for a piece of plexi glass then paint the plexi black. After that cut the holes for the gages and mount. A few notes the speedo will have to work off your VSS sensor or you will have to install a gear adaptor in the trany and run a cable. You may have to rerun the TC lock up strait to the ecm but I dont think so.
Old Jun 14, 2003 | 07:13 PM
Frizlefrak's Avatar
Frizlefrak
Check out this 84 on eBay. Big block, analog guages, etc.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2418473181
Not a great pic of the dash, but maybe you could email the seller and ask for a better pic of the guages.
Old Jun 14, 2003 | 07:46 PM
Lionsden's Avatar
Lionsden
I have this book marked as a source for dash repair.
http://www.unitedradio.com/auto_main.shtml
Old Jun 14, 2003 | 10:54 PM
danno85's Avatar
danno85
I did it in my 85. It's challenging - definitely not a weekend project. I had the
dash (and most of the rest of the car) apart for a bunch of other stuff and
did this at the same time.
But well worth the effort in my opinion.
Dan
[Modified by danno85, 9:55 PM 6/14/2003]
Old Jun 15, 2003 | 04:28 AM
BIG JIM 54's Avatar
BIG JIM 54
The only reason I stay with earlier C4's is for the digital dash. I've had three of them. The dash is dead-nuts accurate, very visible and in the case of the other gauges besides the speedo, a whole lot better than a needle resting ambiguously between two widely spaced numbers, as with the later C4's.
IMO, going away from the digital dash is like going back to 14" wheels.
FWIW,
BIG JIM
To 84 dig. dash to a analog
