Dyno?
Old Jun 15, 2003 | 11:00 AM
nopain1984's Avatar
nopain1984
Default Dyno?
I am going to have my 383(800 miles) dynoed mon.I am running a 650 demon and am looking to have it fine tuned.This is my first time on a dyno, any sugestions?(I was told by the engine rebuild shop it should be around450/450?)My current set up is brodix m2 track1 215cc cnc heads/comp cam 230in/236ex duration-1.6 rockers,110 angle/brodixhv1016 dual plane intake/tpis headers :eek: /punched cat/power effects exhaust/10.25:1 comp/mach 1 reduction pulleys/breathless smog pump eliminator/evans cooling system/My current cab set up is 74 primary/78 secondary/6.5 power valve/36 deg total advanced.I would appreciate any sugestions or recomendations thanks for the help. I'll try to post mon night my results. :chevy
Old Jun 15, 2003 | 04:54 PM
nopain1984's Avatar
nopain1984
Default Re: Dyno? (nopain1984)
no imput :confused:
Old Jun 15, 2003 | 05:04 PM
scorp508's Avatar
scorp508
You will absolutely want the dyno shop to stuff a wideband O2 sensor in your exhaust to get a correct readout of how good your air/fuel mixture is. :yesnod:
Old Jun 15, 2003 | 07:58 PM
nopain1984's Avatar
nopain1984
Default Re: Dyno? (scorp508)
How fast do they run on the dyno?
Old Jun 15, 2003 | 08:05 PM
scorp508's Avatar
scorp508
To whatever your engine is built to handle & make power to. My car makes good power to about 6300, so I let off just after that.
Old Jun 15, 2003 | 08:11 PM
nopain1984's Avatar
nopain1984
Is it run up in 1st gear or all 4 gears?
Old Jun 15, 2003 | 09:31 PM
smallblock's Avatar
smallblock
they ran mine up in 3rd(auto) to get a nice smooth line. 1st would be way too fast :)
Old Jun 15, 2003 | 09:33 PM
scorp508's Avatar
scorp508
You want to do it in whatever your 1:1 transmission gear is. So for smallblock his was 3rd as he said, for me it would be 4th. What transmission do you have?
Old Jun 15, 2003 | 10:04 PM
severe-1's Avatar
severe-1
I know when we want to put some numbers on the dyno with our bikes,
we add about 10 pounds of air to the rear tire. This makes the tire roll easier on the drum, tricking the dyno to show a few more horse.
At the very least, check your tire pressure.
One time I saw a drag bike on
the dyno with a slick. It had maybe 15lbs in the tire. The soft tire kinda
"folded over" the drum and superheated the tire causing it to disintegrate.
Old Jun 15, 2003 | 10:24 PM
nopain1984's Avatar
nopain1984
I have a 700r4. :chevy
Old Jun 15, 2003 | 10:29 PM
nopain1984's Avatar
nopain1984
What pressure should i run?I have it at35lb.1984vette.Kumo's can go to 44psi. :chevy
Old Jun 15, 2003 | 10:36 PM
scorp508's Avatar
scorp508
Then you want to run it in 3rd. You'll need to take it up to something like 50mph and hit the gas to the floor. You need to find the lowest MPH you can hit the gas that it WILL NOT shift into 2nd gear.
So if you nail the gas at say 49mph and it shifts to 2nd you have to try it again at 50. If you nail it at 50 and it stays in 3rd and does a clean pull then use 50. Make sense?
I'd run your tires at whatever your street pressure is to make it the most like you'll always drive it.
Old Jun 16, 2003 | 12:30 AM
nopain1984's Avatar
nopain1984
Default Re: (scorp508)
Thanks for the info.Dino time 10am est.I'll post results tomorrow. :chevy
Old Jun 16, 2003 | 02:53 PM
nopain1984's Avatar
nopain1984
Default Re: (nopain1984)
Fuel pressure was low at upper rpm's :mad I guess i need to get another new fuel pump :mad My existing pump is a 1985 delco(new 500 miles).They recomended a 2800 stall converter/fuel pump and back to the dyno!Rear wheel results were 282.4 hp 287.9 torque :cry Hopefully the pump will help :chevy
Old Jun 16, 2003 | 03:23 PM
scorp508's Avatar
scorp508
Thats a good start! Once you get your fuel issues taken care of she should really come to life. :)
To Dyno?
