Do I even need an FMU???????
Old Jun 16, 2003 | 03:29 PM
vvv90's Avatar
vvv90
Default Do I even need an FMU???????
If I'm running 30lb injectors and a Walbro GSS340 is it even necessary with my setup???
Old Jun 16, 2003 | 05:44 PM
mn_vette's Avatar
mn_vette
Default Re: Do I even need an FMU??????? (vvv90)
Depends on your boost level. More specifically crank horsepower. If your fuel setup can handle it, then all you have to do is have the chip properly programmed. I would assume Fast Chip could do that, but I haven't looked into it. Dyno Tuning is always an option.
Old Jun 16, 2003 | 06:54 PM
dgoodhue's Avatar
dgoodhue
YTour going to need something as your ECM does need boost. You may be able ot do it through a custom chip under power enrichment. Your car is not like a MAF car which can get away with a little boost because it reads air flow.
To Do I even need an FMU???????
