Professional Grade Help Needed!!!
Well any help someone can give would be very helpful!!!
Here is a couple of scans using Datamaster and the bin that I am running now! http://www.users.conninc.com/knight/Scans&Bin.zip
Hopefully your help will smooth out my ride and help me to learn how to smooth it out myself next time!!!!!! :crazy:
im not a programming whiz but i had to post about the map issue before you broke something. im sure someone with the proper experience to help you get it straightened out will chime in .
you may want to i.m. ski_dwn_it. he can burn a chip for you that will make her run like she should.
:flag
:seeya
Save the Wave!
So what do I know so far!
Everyone is telling me not to run a car that is running.
That I should not have moved the MAP sensor.
And that I should change the 1 bar to a 2 bar sensor.
But no one is telling if I change the sensor, What tables do I need to change?
That ia better than lean but not what you want. You haven't said anything about what your running so it is hard to say for sure what you need to do. What kit do you have do you have a fmu ??? Do you have a afpr if yes what is it set at. If you have stock pistons you should not run more than 6lb boost non intercooled or 8lb intercooled this will determine what you do with the fuel. I'm no mind reader I have no idea what you have and you didn't say.
If you have a procharger what size pulley get the boost down install a FMU and the ecm will be ok. If you want to run 10lb or more then you have to change a lot of things but at this point No one can give you any good advice .
Do you have stock pistons
What blower make and model
What size pulley
Do you have a intercooler
Do you have a AFPR
Do you have a FMU
What is your C/R if it is Lt4 C/R will be to high
Everyone asks question about kits and tells me what they would have donew but none answer the question I ask!
I have been building cars for many many years and if some one had asked my to help them tune it. I didn't need to know the compresion rasio, the size piston, etc. I could look at a plug, look at the vacuum, etc. But this is my first time with this style ecm. So my question is if you have a scan or the scan I posted and know what to look for then what does the blower make and model matter? Before you blow any steam, it doesn't! If the car had a carb and dist., I could tune it with out any info! So I know you guy can help me with this, with out all the BS info! I know I can in time! I was just wanting some help on what and where to adjust!
i personally dont see how anyone could have a problem with a forum full of people that take their time to try to help others out for free. but thats just me.
just remember. the man who knows everything, cant learn anything.
BTW: someone already said they couldn't open your scan for whatever reason, why don't you start there. Maybe IM someone, maybe just wait until the right person comes along with experience with the exact same issue, you're not going to get your answer over just a couple days.
Also, you'll find that once you locate the right people to help you, you'll get the answer you're looking for if you're nice. :blueangel:
The people who HAVE posted thus far are just trying to help, even if they don't know the exact answer. The only other option I see is that you wouldn't get any replies at all. At least you're getting SOME response. It's pretty sad when an Irate Irishman like myself has to tell someone else to be patient!
Not to move the map sensor because it doesn't know what to do with vacuum, (but in stock position it only reads vacuum)
Not to run the car because it would be dangerous. (even though I stated that I have been driving the car)
To put on a 2 bar sensor (TRUE - But I would need to redo the tables and that is were I need the help)
To put the 2 bar sensor in the stock location ( I have added a blower! So there is no longer a stock location)
Sorry if I don't see the advice! But All I see is people stating what they have been told or heard before even though it doesn't seem to imply here. I do have a burner and a eraser, I have already removed the original chip and in serted a zip socket, and have burn a few chips to test everything. I have made a few changes but until I learn more of what will affect what I didn't want to change to much!
As for the bin and scans! Would someone try to download it and tell me if it is messed up or if their not even getting it? They were scanned with datamaster. Also it would be nice to IM with someone on this but at this time I only use yahoo IM, I've had problem with the other so I'm leary about putting them back on my computer (but that's another topic altogether)
Again I don't mean to seem ungreatful, but I'm not asking anyone to build my car, so I don't need any advice on what compression, what blower, what drive, or even what plugs. I'm just asking anyone that knows about the tables in reprogramming the ECM help me to understand it more! :iagree:
wrong , it reads vacuum under light throttle , but when you floor it, there is no vacuum. this is how it knows your under full load and gives you max fuel..
the way you have it now, its seeing less vacuum under light load and giving you too much fuel. but if you floor it, it will see more vacuum than your engine actually has & give you less fuel than you need. this will lead to catastropic engine failure.
to do this right , install a 2 bar map in the STOCK location and yes, re do all of the tables that configure fuel based on load.. this is a long drawn tuning process. or , if your nice, maybe someone here has a similar set up , with a close bin file that you can use as a starting point...
But for the up date. I put a vacuum guage were I had the map sensor and on the manifold. there is 3 less lbs of vacuum on the manifold then were I had it, but it is now on the manifold. As for change in vacuum in responce to throttle, that seems to be about the same, as I drive it up the road and back.
As for the 2 bar sensor! When I tried it, it would barely stay running. I had to keep playing with the throttle to even keep it running, and it wouldn't make it to the end of the drive way! So I put the 1 bar sensor back on for now. I know that I have to do a lot of trial and error on the tables until I get it right for the 2 bar sensor, but I need help to get it close enough to even run first!
It's not running that bad as is right now but it still has a lot of room for improvement and it is running rich right now!
So you added a super charger on a 1992 Vette with an LT-1 that is not Speed Density (easy enough the Mass Airflow Sensor will to alot of the tuning)
You say it should be making 6lbs but after driving it ...IT makes 10 lbs (dont see a problem there up the fuel to get it to run 12:1 or so air/fuel)
You moved the MAP Sensor infront of the lower (don’t know why you would do that but what ever...I just would why you would do that and did the motor come stock with a 2 bar or 1 bar?? (That is a question not being rude)
So your real question is referring to the Data master bin you want to get the air/fuel at the right mixture??? (Another question)
Or did you do some tuning and would like to tune some more and see if it cures the rich exhaust state you are having??? (Another question)
We are here to help but there is a miscomunication somewhere?
