While removing a failing oxygen sensor on my 1988 Coupe the threads in the mount on the exhaust got pretty "boogered up". I would like to re-tap the exhaust port before installing the new sensor but have had a hard time getting information as to what size tap to use. I have of course tried to reverse engineer the process by trying to find a bolt that would fit the sensor and then of course I could buy the tap based on the bolt size. On the surface one might think this would be easy but I have been to several different hardware stores and none of the bolts (metric or standard) fit correctly.
Using a caliper in appears that the size of the O2 sensor is 11/16 or about 17 milimeters and the thread spacing seems to be about 16 per inch. Can anyone confirm my measurements. This tap size does not seem to be common so I will probably have to order it when I am sure about the size.
tdock, Thanks for the info. It apprears that the size I need is 18 mm. This will get me on track now. I knew I could count on the forum to guidance. Cheers
I just changed mine this morning along with my thermo. I measured the thread pitch on the old one and it was 18 I cant find my mic so thats the best I can do...good luck
Head for a really good NAPA store. Ask for a spark plug tap. You may get a short tap requiring a 13/16" wrench. This will likely work. You may decide to buy some anit-sieze compound.
