Nitrous pressure question
Old Jun 18, 2003 | 04:25 PM
black_89_vette's Avatar
black_89_vette
Default Nitrous pressure question
TNT Wet 150 shot
NX Express bottle heater
Super rammed 383
When my bottle was full, it would read around 1100 psi (give or take).
Now, I am guessing that my bottle is about half full. It reads around 750-800 psi.
I turn the bottle heater on, but I never really gave it that much time to heat up.
How much will the bottle heater raise the psi to?
But my main question... is there a direct co-relation between psi and power output? Full pressure (1100 psi)=100 % power output. What about 750 psi?
Old Jun 18, 2003 | 04:44 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Nitrous pressure question (black_89_vette)
Posted my answer in the C4 tech thread...
Old Jun 26, 2003 | 09:07 PM
red-y's Avatar
red-y
You need to get your bottle between 900 to 1200.
Less or more is not good. :thumbs:
Old Jun 29, 2003 | 07:41 PM
dizwiz24's Avatar
dizwiz24
PV = nRT.....So both temperature and weight of nitrous (moles) will have an effect on your bottle pressure.
I can say though. I am new to nitrous, but have noticed that i can just have my bottle filled, open the valve, and only be at 700 psi.
Or, when its about empty, I can get into the car on a hot day, and see that its at 1100 psi.
I think temperature has more an effect, even though the ideal gas law states they both have an equal effect.
Use a bottle heater/ insulation blanket to get your bottle pressure to the proper level.
Old Jul 11, 2003 | 03:00 PM
jwood's Avatar
jwood
7th Gear
Freeze your bottles before you get them filled. This will help. Keep pressure between 950-1150
Old Jul 28, 2003 | 11:52 AM
fiberglasscoffin's Avatar
fiberglasscoffin
Default Re: Nitrous pressure question (jwood)
i drop mine off the day before he puts them in a refrigerator overnight
Old Jul 29, 2003 | 10:24 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Nitrous pressure question (fiberglasscoffin)
Why would you want to do that? That would drop the pressure..
Old Jul 29, 2003 | 08:23 PM
black_89_vette
Default Re: Nitrous pressure question (fsr402)
Yes, it drops the pressure, which allows more nitrous to go in when getting filled.
It is a standard practice when refilling.
Old Jul 29, 2003 | 08:44 PM
fiberglasscoffin
:yesnod: :yesnod:
To Nitrous pressure question
