Idle problem with D-1 intercooled sysetm
Old Jun 18, 2003 | 06:16 PM
Allblownup's Avatar
Allblownup
Default Idle problem with D-1 intercooled sysetm
I have about 11 inces vaccuum and cannot get to idle above 650 rpm. I pulled out my IAC and it does reatract. I have opened my idle screw all the way out and have no luck. I have checked all my setting on my Haltech system. I am trying to use map sensor to set idle, but I can use throttle position to set idle.I have not tried it yet. Any input would be appreciated. :seeya
Old Jun 19, 2003 | 06:16 PM
Allblownup's Avatar
Allblownup
Default Re: Idle problem with D-1 intercooled sysetm (Allblownup)
:seeya
Old Jun 19, 2003 | 07:05 PM
krivera's Avatar
krivera
Damn it i know the answer but i can remember to save my ars...ummm have you checked your PVC system...i know when i removed my PVC valves the idle went up and it ran better at idle and boost let the crank case breath baby!
Old Jun 19, 2003 | 07:09 PM
black bart's Avatar
black bart
Did you disconect the iac when you changed the idle screw.
Also when you change screw you have to adjust the tps again did you do that
Old Jun 19, 2003 | 07:12 PM
krivera's Avatar
krivera
Default Re: Idle problem with D-1 intercooled sysetm (black bart)
:iagree: :banghead:
DAMN IT yep TPS sensor why didnt i think of that...See black bart that is why you are the man---> :cool:
Old Jun 20, 2003 | 08:54 PM
Allblownup's Avatar
Allblownup
I will try those things tomorrow. I can recalibrate the TPS with the computer, but due I also need to have the correct voltage? If so what should it be? :seeya
Old Jun 21, 2003 | 06:05 PM
black bart's Avatar
black bart
After reading this I went back and looked at your first post I missed the Haltech, Not familiar with that one but sounds like you can set it like I do my gen,7 Do you click on the tps setting than floor it and click on it again to set the tps parameters. Before I set mine with the computer I set the throttle screw then adjusted tps to 0.54 then set the computer try that it worked for me. When adjusting the idle screw remove the wire from the iac if it is connected when you change the idle screw the computor will change the iac to try to maintain target idle speed :seeya
Old Jun 22, 2003 | 01:53 PM
Allblownup's Avatar
Allblownup
Yes that is how to calibrate the Haltech. I will follow those steps this week sometime. It is pooring rain hear in FL. That sounds like the fix. THANKS!!! :thumbs:
To Idle problem with D-1 intercooled sysetm
