Question about leaking oil fill cap...
Old Jun 18, 2003 | 10:22 PM
rsrandy's Avatar
rsrandy
Default Question about leaking oil fill cap...
Hey Guys,
My 1992 C4 is leaking a little oil from under the oil fill cap. Has anyone else had that problem? The cap seems to be hard plastic on the bottom with out any kind of rubber seal. Is this correct? Also, is there a cap for a different year that would fit and work better?
Randy :chevy :chevy
Old Jun 19, 2003 | 05:11 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Question about leaking oil fill cap... (rsrandy)
Randy,
There should be a gasket under the oil cap.....from long usage and heat it hardens.....this is probably your problem.......get a new cap....maybe chrome....or just install a new gasket....
Hope this helps. Been there done that...
tony
:thumbs: :thumbs: :thumbs:
Old Jun 19, 2003 | 05:15 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Question about leaking oil fill cap... (oldace84)
I think it should have a rubber O-Ring under the cap.. ill check when I get home
Old Jun 19, 2003 | 06:19 PM
C4Crazy787's Avatar
C4Crazy787
Default Re: Question about leaking oil fill cap... (BluByU)
:iagree:
Old Jun 20, 2003 | 09:44 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Question about leaking oil fill cap... (C4Crazy787)
yes.. i jsut looked and can verify it does indeed have a rubber o-ring under the cap..
hope that helps
Old Jun 21, 2003 | 12:17 AM
rsrandy's Avatar
rsrandy
Thanks Guys,
I ordered a new cap from Ecklers. Thanks to everyone who responded.
Randy
:party:
To Question about leaking oil fill cap...
