Antenna problem
Old Jun 19, 2003 | 12:21 AM
sgbagel's Avatar
sgbagel
Default Antenna problem
My antenna on my 1995 coupe doesn't retract all the way staying up about an inch from the base. Any suggestions for how to fix this problem?
Old Jun 19, 2003 | 12:28 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Antenna problem (sgbagel)
it sounds like a piece of ribbion broke off inside of motor i just replaced my mast. it cost me $29 it camewitha tool to take off ring under rubber seal on it was in somtimes mine sticks up some times it doesn't.It allways goes down witha little help.Whatever you do do not oil it it will only get worse .Turn on radio and wipe it down clean cloth.
Old Jun 19, 2003 | 10:56 PM
sgbagel's Avatar
sgbagel
Default Re: Antenna problem (crash1mac)
Thanks for the advice. Iwas going to try WD40 but will go with a clean rag for now.
Old Jun 19, 2003 | 11:16 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If you feel like replacing the entire antenna assembly with a new one(that's what I did), I can help you out, you aren't that far from me.
Old Jun 19, 2003 | 11:24 PM
DroptopMan's Avatar
DroptopMan
Default Re: Antenna problem (Mr Mojo)
I replaced the mast first and it wouldn't go all the way in. But I think the local dealer sold me to long of a mast. Bummer because I couldn't get it out once in. So after that I ordered an entire antenna from Superior Chevrolet and that mast works perfectly but is shorter than I thought it should be. At any rate the top of the antenna is higher than the convertable top so maybe coupes have a higher mast. Hence the first mast wouldn't go all the way down. Anybody know how to get a new mast out of the Antenna? :confused:
Old Jun 20, 2003 | 09:01 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VIII Veteran
I agree that you've probably got a bit of broken ribbon jammed in your antenna motor gear case. The only way to fix is remove your antenna motor, open the case, remove the broken section of ribbon and thread the new mast down the hole once you've installed the motor.
I offer detailed instructions below from CF Tech Tips:
https://www.corvetteforum.com/techti...D=17&TopicID=2 :cheers:
Old Jun 21, 2003 | 12:40 PM
sgbagel's Avatar
sgbagel
Thanks a lot for your offer and if I decide to try to fix it myself I'll get back in touch.
To Antenna problem
