parking brake ?
Old Jun 19, 2003 | 04:27 PM
neverendingproject's Avatar
neverendingproject
Default parking brake ?
what year did they stop using the seperate parking brake? also , are the early rear rotors the same size as any of the other years front rotors?
Old Jun 19, 2003 | 07:50 PM
BAM92's Avatar
BAM92
Default Re: parking brake ? (neverendingproject)
I believe the 84-87 had the seperate ebrake and the smaller rotors.
Old Jun 19, 2003 | 07:55 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I think they made the switch in 88
I cannot speak to pree 88 set ups, but, while the roters and therefore the caliper set ups are 12" front and back, it is curious to note that due to the "hat in the middle of the roter and the height of the caliper, the 88 front brakes have more swept area than the rear
Again, can't speak to other years. I put C5's on the front of my 88 and this winter, I will probably replace my 88 rears with my 88 fronts...then when I step on the brakes I will hit my nose on the windshield :D :D :D
:seeya
:steering:
Old Jun 19, 2003 | 08:31 PM
neverendingproject
Default Re: parking brake ? (jackdaroofer)
thats why i was asking. i want to put c5's on the front and put the fronts off another year on the rear. since the parking brake is seperate from the caliper, i thought , if i find a good caliper that will work with the rear rotors , should be cake. any other resonable options are also appreciated , of course.
Old Jun 19, 2003 | 09:19 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
You will probably have to "loose" emergency brake, I plan to, since I can't even remember where the handle is :D
Old Jun 19, 2003 | 09:22 PM
neverendingproject
no can do,,, part of the yearly inspection procedures. pull the handle and floor it.
To parking brake ?
