compression ratio '85
Old Jun 19, 2003 | 05:52 PM
atotalnincompoop's Avatar
atotalnincompoop
Default compression ratio '85
My brother needs a motor for his truck, I have the original motor out of my '85 and an old set of 64cc heads. does anyone know what the compression ratio would end up at if you put 64cc heads on a stock '85.
thanks Greg
:cheers:
Old Jun 19, 2003 | 06:27 PM
MrNuke's Avatar
MrNuke
Default Re: compression ratio '85 (atotalnincompoop)
IF the '85 engine is in good condition and compression is still good on it, I'd guess 9.8 or around there.
Stock is 9.5 with 74cc or is it 76cc iron smog heads..
Old Jun 19, 2003 | 07:00 PM
montie98's Avatar
montie98
Default Re: compression ratio '85 (MrNuke)
Has anone out there ever heard the rumor that some 85s accidently were built with a higher compression ratio?
Old Jun 19, 2003 | 09:22 PM
atotalnincompoop
Default Re: compression ratio '85 (montie98)
they have forged pistons :yesnod:
Old Jun 19, 2003 | 09:31 PM
Bluevette85's Avatar
Bluevette85
Stock 85 with iron heads 9.0:1
Old Jun 19, 2003 | 09:32 PM
atotalnincompoop
Default Re: compression ratio '85 (Bluevette85)
ok, but what if i changed the heads from 76cc to 64cc?
Old Jun 19, 2003 | 09:53 PM
Bluevette85
Try this compression ratio calculator:
http://www.rbracing-rsr.com/compstaticcalc.html
Old Jun 19, 2003 | 10:06 PM
CFI-EFI's Avatar
CFI-EFI
The condition of the engine and how much compression it has, will NOT affect the compression ratio. The compression ratio is a numeric comparison of the total volumes exsisting at tdc and bdc.
This is just arithmatic.
RACE ON!!!
1984 Crossfire
Member NHRA
[Modified by CFI-EFI, 8:10 PM 6/19/2003]
Old Jun 20, 2003 | 05:39 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: compression ratio '85 (CFI-EFI)
IF the compression ratio is in fact 9.0:1 with 76 CCs, You're looking at an increase to 10.2:1 :yesnod:
You don't need those equations if you know the original ratio and the changes in chamber volume.
R1,R2 = comp ratio, before and after
D = displacement per cylinder (350/8 cid = 716.6 cc)
C1,C2 = cyl head vol, before and after
CC= combustion chamber volume
R2 = 1+ D / [D / ( R1 - 1 ) + C2 - C1]
:cheers:
[Modified by CentralCoaster, 3:13 AM 6/20/2003]
Old Jun 20, 2003 | 11:01 AM
atotalnincompoop
Default Re: compression ratio '85 (CentralCoaster)
:cheers:
thanks guys :cheers:
To compression ratio '85
