POS is leaking rain water
-Jason 89 POS Coupe. :rant:
Guess I'm just a Putz....But then again I never drive my vette in heavy rain if I know it is leaking???????
But anyway....what is POS?????
Thank-you
tony
:confused: :confused:
And as far as any advice- have you recently replaced your roof panel? When I got a new one it was adjusted wrong, so it didn't seal tight against the front weatherstripping. Readjusting the top brackets took care of most of the leak, but it still drips just the littlest bit from the top windshield molding. Maybe you could try removing that piece of molding, which is along the top of the windshield? Maybe water is getting in there and running down the a-pillars, and so on?
Hang in there kid....better times are comming...if you work for them....I can remmember running an extention cord out to the camaro to keep woking on it at night......
Sorry...
Good Luck.
Keep up the hard work....
You deserve the best....
tony
:thumbs: :thumbs: :thumbs: :thumbs:
[Modified by oldace84, 6:06 PM 6/19/2003]
http://forums.corvetteforum.com/zerothread?id=406769
This should help.
Do you park on an inclineor level? I'm not certain where the drains are on the coupes, but on C4 verts they are on the forward edge of the rear deck lid channel. If you park nose up, the channel fills up and you have niagra falls on the interior rear storage area. If you snake out the drain holes and park nose down, then you don't have that problem.
Other area is the bottom of the doors. This is where GM really screwed up the design on verts. THe drains are AFT, requiring nose UP to drain. But then the rear deck leaks. :rolleyes: The water runs off the roof, down the windows to the inside of the door (the outer felts are not water impenetrable) and there are gaps at the ends and then should drain out the hole at the back of the door. Fundamentally incompatible with nose down parking. :crazy:
Have you checked the firewall where the wipers park? Those screws holding the wiper park thing should have goopy sealant on them. There are probably other screws in that firewall which might allow leaks if not sealed properly.
Can you tell if it's coming in from the doors? On mine the windows weren't adjusted properly. The water ran along the aft edge of the window and got onto the body door opening on the rear vertical 'wall' where the door latch hooks. the way this is angled the water runs down, and then forward, under the sill and into the front wheel wells. That was a real bugger to try to figure out. Way I finally traced it down was to dry the door opening, stick it in the rain. Carefully open the door and inspect for where it was wet.
Have fun. Water leaks suck big-time. :boxing If all else fails, start calling her your portable shower and she might behave better. :rofl:
