Anyone have coilovers? Help me with the basic set up, please!
I've got an '84 tub with later model outboard suspension front and back, except I have retained the '84 upper control arm. The tub has been lightend, the engine moved back and down. Corner weights with driver and 1/2 fuel load are:LF 651, RF 623, LR 633, RR 601. The application is for roadracing.
The car seems too stiffly sprung, especially in the front, it chatters across the corners. I wish to go down (from stock Z51) spring rates and also reduce the shock rates appropriately.
The current valving is F: 360 rebound/135 bump R: 540 rebound/360 bump.
The current spring rate is ?does anyone know? I think around F: 425#/ R: 375#?
I have found suitable Bilstein racing shocks valved at 300/100 for the front.
I could not find racing shocks that would fit within the measured ranges of compression and extension for the rear, so I suppose I will keep the rears as "production", forgoing the sperical end mounts and perhaps just revalve them.
I think a reasonable spring rate might be F:400, R:350. Any ideas?
I also have questions like:
--How far forward do you need to move the rear upper mounts to keep the springs form hitting the halfshafts?
--Can you fit a 2 1/2 coil spring through an '84 upper control arm?
Suspension Guru's chime in. speedj
[Modified by speedjohnson, 11:19 PM 6/20/2003]
[Modified by speedjohnson, 11:47 PM 6/20/2003]
1. The 2-1/2" springs should work on the front of your '84, my '85 has them.
2. 350 will probably be too much for the rear. I started at 300 and couldn't get enough weight transfer when applying throttle. I now have 250 rear/500 front. I had 450's up front and a zip tie around the shock rod told me they were bottoming out.
3. You will avoid a lot of headaches and jerryrigging in the rear if you get the heim-jointed trailing arms. I have the Guldstrand set and it allows you to move the trailing arm a lot closer to the knuckle, increasing spring clearance. If you use the stock trailing links you will have to shim it and your shock won't travel through its intended range of motion. Here's a few shots of the trailing links: (BTW the contact marks on the spring are from before I had the heim jointed trailing links)
And here is the length of the shorter bolt vs. the stock bolt for the trailing link/knuckle (it doesn't appear that much shorter, but its the shoulder where the threads go to that's important here):
Hope this helps. :seeya
Oh, Here's why you need the shorter bolt - the Guldstrand hardware uses spacers and the stock bolt. Also, when you go to coilovers you reverse the direction of the bottom trailing link-to-knuckle bolt. The head of the bolt takes up less space than the threads and nut.
Also notice that the bottom of the shock is spaced away from the knuckle. You can see that the shock and its lower mount are not perpendicular as they should be. If you compare the rubber bushings of the left suspension to the right suspension, you can see that the shock is kinda in a bind on the right (last) photo. The driver side which has been corrected needs no spacers and the shock travels smoothly in the direction it should.
:smash:
Oh, and a simple fix for a rubbing spring (sounds like a no-brainer but it didn't come to me immediately and I think i'm OK) but turn the springs! I had trouble with the front sway bar rubbing and just a simple turn of the spring and it doesn't touch. Also, if the tires are off you can use a large pry bar to take weight off the spring adjusters enough to turn them by hand, making adjustments a lot easier. Not much good for scaling, the tires get in the way. Maybe a set of thinner tires for scaling/storing/moving the car around the shop? Hmmm.... :rolleyes:
[Modified by vetracer, 6:22 PM 6/20/2003]
One more Q? Are you using 2 1/2 x 8" springs or 2 1/2 x 10" springs?
Your help has saved me a ton in development and wrong choices. Thanks! sj
:lurk:
You will of course also need the spring retainers and may have to spread out the flanges on the sides of the top front shock mounting location slightly to make enough room for the spring to slide into it. It won't be noticeable, though.
[Modified by vetracer, 7:08 PM 6/20/2003]
[Modified by superlund, 9:11 AM 6/22/2003]
These 10 inch springs just barely fit rear the shocks. They are almost too long. You have to preload them and the coilover mount is turned all the way down. The ride height is about right when the car is let off the jacks, but really no adjustment room to lower any more. I wonder if an 8" spring would work or if it would coil bind? Any one using 8" springs in the rear?
You are right about the rear springs. Maybe an 8" spring WOULD work better, but I don't know, never tried it.
To deal with the rear shock mounts, I moved them forward 1" and sunk them into the frame rail; moving them up another 1/2 inch or so. This gave me alot more clearance with the trailing arms/ halfshafts. It looks like I still have a good amount of suspension travel, approximately 2 3/4" into bump and 2 1/2" in rebound. The bump steer really was off alot, especially after about 1 1/2" bump ... those adjustable toe rods really worked out sweet!
The front shocks arrived today. They are a Bilstein oval track racing shock. The shortest I could find was 16+ inches extended and 11+inches compressed; about two inches longer than stock, so I relocated the upper mount to a stiffener bar that runs horizontal to the forward frame rail, which looks like it will work just fine. The shocks are linear valved at 300/100 (20% less that Sears Point valving) and I will try them with a 400-450" spring to start.
How did you deal with the front sway bar? It looks like it will interfere with the front coilover and you would have to move it forward. The problem with that is the bar will limit turn in at full lock, as it hits the inside of the rim. Did you move yours or did you just get creative with the end links?
I'll keep you posted on the final result, we've got a double regional July 4th weekend @PIR.
In the front
[Modified by speedjohnson, 9:55 PM 6/23/2003]
[Modified by speedjohnson, 9:59 PM 6/23/2003]
Moving the top shock mount would definitely help half shaft and trailing arm clearance. Sounds like a great setup! :thumbs:
Oh, your question about the sway bar: this is where turning the springs comes in. If you turn the spring with the car at rest and suspension settled so that nothing is touching you should be fine. As far as I can tell, the sway bar isn't making contact with the spring even though it APPEARS that it would.
Do you have the 1" aluminum spacer blocks that go between the frame and the bushings like what Guldstrand sells? Apparently this block improves the geometry of the sway bar and makes it more effective, although I don't remember exactly how.
[Modified by vetracer, 10:53 PM 6/23/2003]
