LTPWS System Warning Lit Up
Old Jun 20, 2003 | 07:15 PM
Jeff Blowers's Avatar
Jeff Blowers
Cruising
Default LTPWS System Warning Lit Up
Does anyone have any thoughts on what I could do to troubleshoot this warning light? I have tried removing the negative to battery just so everything in the PCM is re-set but that warning light came back on.
Thanks in advance.
Old Jun 20, 2003 | 07:26 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: LTPWS System Warning Lit Up (Jeff Blowers)
What year do you have?
Old Jun 20, 2003 | 07:32 PM
K&L's Avatar
K&L
3rd Gear
I had a similar issue with mine, probably one of the wheel transmitters gone bad. Another user posted a way to troubleshoot which wheel is the issue but I forget who. Their suggestion was to lower the pressure in one tire, say 20lbs and drive SLOWLY around the block to see if the Low Tire Pressure light came on, if it does, that wheel is good, pump it back up and try another until you locate the bad transmitter.
My Chevy dealer told me it was a Goodyear system and have them test it.
Old Jun 20, 2003 | 08:21 PM
Mikesa's Avatar
Mikesa
If you can get your hands on a Service Manual, all the steps are there. If there is a sensor failure, the fault code is stored and available by grounding pin B to pin A at the ALDL with the ignition on. The ALDL is under the dash on the drivers side near the console, if I remember correctly. With a low tire pressure signal, the code is available while the warning is there, the code for low tire pressure stays stored even if you pump up the tire, until the module resets when the ignition is turned off and back on. The control module memory for the sensor fault codes can be cleared by grounding pin B to pin A, at the ALDL connector 3 times within 10 seconds
Low tire codes Wheel sensor fault codes
rt rr 23 24
lt rr 33 34
lt frt 43 44
rt frt 53 54
I'm no mechanic, but this is what I got from the service manual.
Old Jun 21, 2003 | 12:41 AM
PALERYDER's Avatar
PALERYDER
Yes, I got that light too. Found out 1 of my rear wheel wheels LTPW sensors system was acting up. I ended up removing the bulb out of the dash warning panel cluster. That fixed it for good. But belive it or not; if I do get a low tire pressure, which I often do, cause I intensionally lower the tire pressure for the drag strip (below 25 psi). I still get the other light on "Low/Flat Tire". :cheers:
Old Jun 25, 2003 | 02:03 PM
mcdanpd's Avatar
mcdanpd
1st Gear
Default Re: LTPWS System Warning Lit Up (Mikesa)
I recently purchashed a sweet 96 flame red black top vert. I love every thing about the car except the LTPWS. It comes on every day and stays on until the engine is turned off. My dealer said the sensor was bad and it would cost $350.00 to replace. I've read what PALERIDER wrote and will try and turn it off for good. Any more advice on this problem. Desperate in OK. :auto:
Old Jun 25, 2003 | 02:42 PM
HTRK-1's Avatar
HTRK-1
Default Re: LTPWS System Warning Lit Up (mcdanpd)
I'm not trying to be a smart "a" but when mine came on, I actually found 1 tire with low pressure.
Old Jun 25, 2003 | 03:52 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: LTPWS System Warning Lit Up (PALERYDER)
Paleryder, I think you have another bulb to pull.
[Modified by lou sylvestri, 12:54 PM 6/25/2003]
Old Jun 25, 2003 | 09:14 PM
Mikesa's Avatar
Mikesa
Default Re: LTPWS System Warning Lit Up (HTRK-1)
Same thing with me (duh). Mine were all at 25-26 lbs. Things should always be that easy.
Old Jun 26, 2003 | 06:02 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
About 2 years ago, I was occationally having a false warning on my 1996. I put the word out on the forum and a guy by the name of Fredrick Bush said he had a new sensor. I sent him the money and he stiffed me. So, don't buy anything from this guy. The name again is Fredrick Bush.
The sensor stopped acting up and nothing for the past 2 years.
Old Jun 26, 2003 | 09:20 AM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Default Re: LTPWS System Warning Lit Up (Mez)
You can buy new sensors at GM Parts Direct for less than 100 bucks each.
w w w.gmpartsdirect.c o m
To LTPWS System Warning Lit Up
